Is your battery no longer able to hold a charge? Or do you have multiple batteries for your Sony Vaio PCG-161L? You only need your hands and a couple of minutes to change your battery.
Flip your device over so the bottom panel is facing up.
Slide the lock switches below the battery to the unlocked position.
Lift up the battery, rotating it up and away from you, then pull it out.
