Screen cracked? Needs replacing? Look no further!
Unlock the screen and flip it so that the screen is in tablet mode.
Looking at the back of the screen, remove all 8 screws using a Phillips #0
Use a plastic spudger to carefully remove the back cover of the screen.
Reveal internal screen components
Remove all 10 screws
Carefully remove each end of the connector strip from the back panel.
Feed the disconnected ribbon highlighted in blue through the slot in the metal frame.
Disconnect section of the screen connector highlighted in blue.
Gently pull up on the tape at the bottom of the ribbon to unplug the screen connector from the screen.
The screen can now be removed and replaced.
