If your computer is not powering on or holding a charge then you might need to replace your battery.
Begin by turning the laptop top-down on a flat surface.
Use a JIS #1 screwdriver to remove the 4 screws circled in red
Use a JIS #0 screwdriver to remove the 8 screws circled in orange
Use a spudger to carefully remove the back cover of the laptop.
Lift up back cover to access internal components of the laptop.
Remove the screws in the circled areas using the J0 Screwdriver to release the battery.
Lift the battery from the laptop to remove.
Replace if necessary.
