Sony Vaio Duo 11 SSD Replacement
crwdns2942287:0crwdne2942287:0Before start the procedure, make a system backup (I use ToDo Backup Free).
Some pictures were found in:
http://henjinkutsu.com/text/pc/svd1121aj...
Using a spudger, remove the rubber screw covers.
Gently remove the speaker covers.
With they way the speaker covers are taped on, I wasn’t able to remove without bending/damaging the covers.
Use a sharp tool to lift up the laptop's cover
Remove all the screws. (Attention: these screws are different! Save them.)
Remove the cover carefully. One side is attached with a short, flat, white cable. (Attention: Don't detach the white cable.)
Remove the screws (circled in red) and remove the battery.
When reassembling : Remember to hide the piece of plastic beside the battery (circled in the second picture) behind the plastic. Otherwise you will not be able to press the right mouse button.
Detach flat cable. To do so, you have to lift the black plastic bar, then release the orange ribbon.
Remove these screws to make it easier to remove the SSD.
On mine, model #Svd11223cxb, There were 2 screws to remove (The two under the fan), The third (beside batter connector) was already removed in the base/cover disassembly.
The remove of the ssd
Remove the SSD (gently)
Replace the SSD ( it is a mSATA SSD )
Put back the screws and close the unit
crwdns2935229:026crwdne2935229:0
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0crwdns2947412:014crwdne2947412:0
Mind BLOWING!!!!!!!!!!!!! Job, Bro..... It Helped me a Lot.....
1TB ssd here I come!!!!
It worked! Can't believe it. I exchanged my 128GB one with a Crucial 500 GB one. Used the Acronis True Image that came with the new SSD. Still getting used to having so much free space :D
Hi, I tried to upgrade to a 256GB SSD using shadowprotect and EaseUS to restore the image, but the drive would never boot. The SSD was not the problem as it worked fine when installing Windows from scratch. Did you simply restore a disk image with Acronis?
gps -
Thanks for this tutorial. I typically avoid working on my laptops and gadgets due to overwhelming hidden gotchas. This made swapping out my broken hard drive quick and painless. Thanks again!
Thanks so much!! It worked for me though somehow my internal speakers and headphones are gone (After re-installing custom windows 8.1) Could the yellow flexible flat cable be in any way connected to the sound card? I would appreciate any help
Try this: Go to Control Panel>System and Security>System and to the left, click on Advanced System Settings. Worked for me:
tenebro -
J'ai un vaio duo 11 à vendre
Intel Core i5-3337U 1.8GHz / 8Go de Ram / Windows 10 Argent En plus de l'ordinateur, une carte mémoire 256Go et une pochette de transport en cuir.
Le prix neuf de l'ordinateur était 1600€
What's the implications with the Short flat cable?
Hi, where can I buy a replacement SSD to suit my SONY VAIO SVD112A1SW?
Hi, what do you do with old SSD?
I understand that this model discontinued
Is they any source to get a new battery
How to solve this SVD1322C5E.
J50088J4
S/N: 547100550001353.
Récupération
Votre PC n' a pas pu démarrer correctement.
Le systéme d' exploitation de votre PC n'a pas pu démarrer malgré plusieurs tentative et doit donc étre réparé.
code d' erreur : 0xc00000001
vous devrez utilitiser Les outils de récupération. Si vous me disposez d' aucum média d' installation ( tell qu un disque out un périphérique USB). contactez votre administrateur systéme ou le fabricant de votre ordinateur / périphérique.
Appuyerz sure la touche windows pour accéder aux paramétres de microprogramme UEFI.
J50088J4
Récupération
458
