Sony VAIO VPC-EB33FM Hard Drive Replacement
  1. Sony VAIO VPC-EB33FM Hard Drive Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony VAIO VPC-EB33FM Hard Drive Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Power down the laptop by pressing the power button.
    • Turn the laptop onto its backside.
  2. Sony VAIO VPC-EB33FM Hard Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To release the battery, hold both the release button and the unlock button at the same time.
  3. Sony VAIO VPC-EB33FM Hard Drive Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony VAIO VPC-EB33FM Hard Drive Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the battery out from the notch while continuing to hold the release button.
  4. Sony VAIO VPC-EB33FM Hard Drive Replacement, Hard Drive: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony VAIO VPC-EB33FM Hard Drive Replacement, Hard Drive: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony VAIO VPC-EB33FM Hard Drive Replacement, Hard Drive: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the two 7.8 mm cover screws on the bottom corners of the panel.
  5. Sony VAIO VPC-EB33FM Hard Drive Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony VAIO VPC-EB33FM Hard Drive Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony VAIO VPC-EB33FM Hard Drive Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a finger/fingernail to grip the notch at the bottom of the panel to lift it off.
    • You may need to use your other hand to safely remove the panel.
    • You can also use a spudger for this step.
  6. Sony VAIO VPC-EB33FM Hard Drive Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two remaining 7.8 mm screws using the Phillips #00 screwdriver.
  7. Sony VAIO VPC-EB33FM Hard Drive Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grab the tab between your thumb and index finger.
    • Hold the hard drive securely in a horizontal position using your other hand.
    • Push the hard drive to the left using the plastic tab to disconnect it from the laptop.
    • To prevent damage of the connection on the hard disk drive or the laptop, perform this task slowly and with care.
  8. Sony VAIO VPC-EB33FM Hard Drive Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony VAIO VPC-EB33FM Hard Drive Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • While still holding the plastic tab, lift the right side of the hard drive out at a 45º angle.
    • Pull the hard drive out.
  9. Sony VAIO VPC-EB33FM Hard Drive Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony VAIO VPC-EB33FM Hard Drive Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • If you need to remove the bracket from the hard drive, follow the next few steps:
    • Remove the two 3.7 mm screws from either side of the bracket with a Phillips #00 screwdriver.
    • Lift the bracket off the hard drive.
crwdns2935229:09crwdne2935229:0
Christian
crwdns2935283:001/14/13crwdne2935283:0
195 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 18-39, Regan Winter 2013 crwdns2935289:0Cal Poly, Team 18-39, Regan Winter 2013crwdne2935289:0
CPSU-REGAN-W13S18G39
This is very good step by step instructions guide. Loved it and was able to remove my laptop hd very easily. I created this account only to say thanks to writer. Amazing job !! Thaks ton.
Dinesh - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 18,632
