This guide will help you replace the Sony VAIO SVE14AJ16L I/O Card on your laptop. An I/O card is an important piece that represents the relationship between inputs and outputs in a computer system. I/O cards play a vital role as a link between a computer and external devices, spanning from monitors to keyboards. When an external device sends a signal, it is received by the I/O card, triggering a corresponding action. If you notice that what you input into your computer is not outputting correctly, your I/O card needs to be replaced. In this tutorial, we will guide you through the safe replacement of your device's Sony VAIO SVE14AJ16L I/O Card.
Overall, this replacement is straightforward and should be completed in a few simple steps if completed carefully and with precision. The only tools you will need are the iFixit opening tool, magnetic project map, tweezers and an Phillips #0 screwdriver.
Flip the laptop so the bottom side is facing up towards you.
Remove the battery, hard drive cover, and RAM cover.
Unscrew the two Phillips screws to remove the hard drive from the computer
crwdns2935267:0crwdne2935267:0Magnetic Project Mat$16.96
Remove the 13 Phillips #0 screws.
Carefully pry apart the clipped-on bottom panel of the laptop to expose the internal of the laptop using the iFixit opening tool.
Locate the I/O card in the bottom left hand corner of the case.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Carefully slide the black retainer bar towards the ribbon cable with a nylon supdger until parallel.
Carefully pull the ribbon cable out of its socket with a pair of tweezers.
Remove the two screws on the corners of the I/O card using a Phillips #0 screwdriver.
Lift the edge of the card up and away from the laptop, then pull it away from the side ports.
To put Humpty Dumpty together again, follow these instructions in the reverse order.
