Sony VAIO PCG-933A Fan Replacement
  1. Sony VAIO PCG-933A Fan Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony VAIO PCG-933A Fan Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the laptop upside down so that the top is sitting on a flat surface.
    • If you are looking at the bottom of the laptop the battery is located on the front right side of the laptop; the opposite side from the floppy disk drive.
  2. Sony VAIO PCG-933A Fan Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony VAIO PCG-933A Fan Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony VAIO PCG-933A Fan Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • As shown by the arrow, slide the plastic cover up and then pull out and downwards.
    • You should now be able to pull the battery out.
  3. Sony VAIO PCG-933A Fan Replacement, Keyboard: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 16 mm screws bordering the edge of the laptop using a Phillips #0 screwdriver.
  4. Sony VAIO PCG-933A Fan Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony VAIO PCG-933A Fan Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 4mm screw on the right rear side of the laptop next to the audio ports using a Phillips #0 screwdriver.
    • This will release the speaker grille.
  5. Sony VAIO PCG-933A Fan Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the computer so the key board is facing up.
  6. Sony VAIO PCG-933A Fan Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony VAIO PCG-933A Fan Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony VAIO PCG-933A Fan Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the blue speaker grille (located above the keyboard) to the right and gently pull upward. The grille will still be connected by a white electrical strip.
    • Carefully pull out the white electrical strip. By doing this you will remove the speaker grille.
  7. Sony VAIO PCG-933A Fan Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony VAIO PCG-933A Fan Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony VAIO PCG-933A Fan Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 4mm screw in the center using a Phillips screwdriver.
    • Carefully and slowly pull the green strip straight up (away from the laptop) to disconnect it. Make sure not to pull too hard to avoid breaking.
    • The keyboard can now be removed.
  8. Sony VAIO PCG-933A Fan Replacement, Fan: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony VAIO PCG-933A Fan Replacement, Fan: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony VAIO PCG-933A Fan Replacement, Fan: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four 4mm Phillips screws around the hard drive.
    • WARNING: DVD drive is now loose as well
    • Carefully lift the hard drive cage out.
    • Carefully disconnect the copper strip to pull out the hard drive.
  9. Sony VAIO PCG-933A Fan Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony VAIO PCG-933A Fan Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With the hard drive removed, unscrew the four 6mm brass colored, Phillips screws under the hard drive cage.
    • This will allow you to remove the hard drive mounting bracket.
  10. Sony VAIO PCG-933A Fan Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 6mm brass colored, Phillips screws that hold the fan cage in place.
  11. Sony VAIO PCG-933A Fan Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony VAIO PCG-933A Fan Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 4mm black, Phillips screws shown here.
    • Remove the 18mm silver, Phillips screw shown here.
    • Now remove the silver tab.
  12. Sony VAIO PCG-933A Fan Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony VAIO PCG-933A Fan Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the blue and red fan power cords.
  13. Sony VAIO PCG-933A Fan Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony VAIO PCG-933A Fan Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully pull up and out on the metal heat sink and fan bracket.
    • The fan can now be cleaned or replaced.
Sara Lillard
crwdns2935283:004/11/11crwdne2935283:0
165 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 12-36, Maness Spring 2011 crwdns2935289:0Cal Poly, Team 12-36, Maness Spring 2011crwdne2935289:0
CPSU-MANESS-S11S12G36
crwdns2942667:0crwdne2942667:0 2,529
