Sony UBP-UX80 Wi-Fi Card Replacement
  1. Sony UBP-UX80 Wi-Fi Card Replacement, Top Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony UBP-UX80 Wi-Fi Card Replacement, Top Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony UBP-UX80 Wi-Fi Card Replacement, Top Cover: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #2 screwdriver to remove the two 10.5 mm screws that secure the two side panels onto the back of the player.
    • Slide both covers back about a 1/2 inch, then pull them away from the case.
  2. Sony UBP-UX80 Wi-Fi Card Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony UBP-UX80 Wi-Fi Card Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony UBP-UX80 Wi-Fi Card Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #2 screwdriver to remove the two 10.5 mm screws on the side of the case, each connecting to a tab on the cover.
    • Similar to the previous step, it is identical cases on both sides of the device.
    • Use a Phillips #2 screwdriver to remove the two 10.5 mm screws (one next to the Wi-Fi logo and one next to the Blu-ray logo).
  3. Sony UBP-UX80 Wi-Fi Card Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony UBP-UX80 Wi-Fi Card Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Press in the tabs found on the front-sides of the case (connected to the front panel).
    • Slide the top cover forward.
    • Lift off the case.
  4. Sony UBP-UX80 Wi-Fi Card Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony UBP-UX80 Wi-Fi Card Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony UBP-UX80 Wi-Fi Card Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Find the eleven 10.5 mm silver screws and two 6 mm black screws on the perimeter of the silver cover plate.
    • Remove the silver screws using a Phillips #2 screwdriver and the black ones using a Phillips #1 screwdriver.
    • Life the back of the cover up and off of the chasis.
  5. Sony UBP-UX80 Wi-Fi Card Replacement, Front Cover: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony UBP-UX80 Wi-Fi Card Replacement, Front Cover: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony UBP-UX80 Wi-Fi Card Replacement, Front Cover: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Toward the panel there is a ribbon cable with 4 small black pieces of tape holding it down
    • Pull directly up on the ribbon cable to disconnect it from the motherboard
    • Gently pull the cable back away from the motherboard pulling the tape off with it
  6. Sony UBP-UX80 Wi-Fi Card Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once all pieces of tape have been pulled up, the ribbon cable should look like this.
  7. Sony UBP-UX80 Wi-Fi Card Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony UBP-UX80 Wi-Fi Card Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • There are screws on every side of the front panel holding it in. Use a #2 Phillips head screwdriver to remove the nine screws.
    • Unscrew the three 10.5 mm long ph #2 screws on the top.
    • Unscrew the four 10.5 mm long ph #2 screws on the bottom.
  8. Sony UBP-UX80 Wi-Fi Card Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony UBP-UX80 Wi-Fi Card Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #2 screwdriver to remove the 10.5 mm screws, one on each side of the device.
  9. Sony UBP-UX80 Wi-Fi Card Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony UBP-UX80 Wi-Fi Card Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony UBP-UX80 Wi-Fi Card Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift tab on the left side of the device
    • Work your way right, lifting the next tabs. One on the bottom and one the Top
    • Continue working the tabs on the top and bottom, keeping them from snapping back in place.
  10. Sony UBP-UX80 Wi-Fi Card Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once all tabs are disconnected, pull the front panel forward to fully disconnect it
  11. Sony UBP-UX80 Wi-Fi Card Replacement, Wi-Fi Card: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony UBP-UX80 Wi-Fi Card Replacement, Wi-Fi Card: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the power connection by pulling it straight back and out of the card.
  12. Sony UBP-UX80 Wi-Fi Card Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony UBP-UX80 Wi-Fi Card Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the gold-colored connection, remove the tape, and pull it off using the wire. Be gentle because the wire is very small as is the connection.
  13. Sony UBP-UX80 Wi-Fi Card Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #2 screwdriver to remove the two 4.6 mm screws that secure the card.
  14. Sony UBP-UX80 Wi-Fi Card Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift up slightly on the back of the card, and pull out (toward the back of the chassis).
Nate Picard
crwdns2935283:003/13/23crwdne2935283:0
349 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 2-5, Petersen Spring 2023 crwdns2935289:0UMass Dartmouth, Team 2-5, Petersen Spring 2023crwdne2935289:0
UMASSD-PETERSEN-S23S2G5
crwdns2942667:0crwdne2942667:0 185
