Sony UBP-UX80 Motherboard Replacement
  1. Sony UBP-UX80 Motherboard Replacement, Top Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony UBP-UX80 Motherboard Replacement, Top Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony UBP-UX80 Motherboard Replacement, Top Cover: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #2 screwdriver to remove the two 10.5 mm screws that secure the two side panels onto the back of the player.
    • Slide both covers back about a 1/2 inch, then pull them away from the case.
  2. Sony UBP-UX80 Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony UBP-UX80 Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony UBP-UX80 Motherboard Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #2 screwdriver to remove the two 10.5 mm screws on the side of the case, each connecting to a tab on the cover.
    • Similar to the previous step, it is identical cases on both sides of the device.
    • Use a Phillips #2 screwdriver to remove the two 10.5 mm screws (one next to the Wi-Fi logo and one next to the Blu-ray logo).
  3. Sony UBP-UX80 Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony UBP-UX80 Motherboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Press in the tabs found on the front-sides of the case (connected to the front panel).
    • Slide the top cover forward.
    • Lift off the case.
  4. Sony UBP-UX80 Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony UBP-UX80 Motherboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony UBP-UX80 Motherboard Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Find the eleven 10.5 mm silver screws and two 6 mm black screws on the perimeter of the silver cover plate.
    • Remove the silver screws using a Phillips #2 screwdriver and the black ones using a Phillips #1 screwdriver.
    • Life the back of the cover up and off of the chasis.
  5. Sony UBP-UX80 Motherboard Replacement, Motherboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four ribbon connections running to the motherboard:
    • Remove the three ribbon cables from the disk drive by pulling straight up.
    • Remove one ribbon cable from the front panel by pulling straight up.
  6. Sony UBP-UX80 Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the two power connections from the power board.
    • Disconnect the power connection from the front panel.
    • Do not pull on the wires
  7. Sony UBP-UX80 Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony UBP-UX80 Motherboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony UBP-UX80 Motherboard Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #2 screwdriver to remove the seven 10.5 mm screws that secure the motherboard to the case.
    • Remove the three 10.5 mm silver screws from the back of the case.
    • Remove the two 7 mm black screws from the back of the case.
  8. Sony UBP-UX80 Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony UBP-UX80 Motherboard Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the front of the motherboard using the heat sink, slide forward and out of the case.
Kenny Young
crwdns2935283:003/13/23crwdne2935283:0
413 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 2-5, Petersen Spring 2023 crwdns2935289:0UMass Dartmouth, Team 2-5, Petersen Spring 2023crwdne2935289:0
UMASSD-PETERSEN-S23S2G5
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 206
