If you have a problem with starting-up the OS, or if you want to erase all data, or you forgot your password, PIN, pattern code you can do a Factory reset.
Attention!!! This will erase all your data!!! It's good to do BACKUP first.
crwdns2936621:0crwdne2936621:0
Metod 1:
- Settings
- Backup & reset
- Factory data reset
The tablet will restart automatically.
!!! From the "Backup & reset" menu you can do Back up my data !!!
Metod 2:
Power of the tablet. Pres and hold the Power On key and the Volume Up key at the same time.
When you see the Sony logo release the Power On button but continue to press the Volume Up button.
Now you are in the Android recovery menu. Use Volume keys to scroll and the Power On key to select. From the options select:
- Reset to Factory Settings
- Yes - erase all user data
- The tablet will restart alone
crwdns2935229:019crwdne2935229:0
crwdns2944067:023crwdne2944067:0
Hallo , I follow the steps , nothing is happening . Exists a different way ? dedudan@yahoo.com
hi man
i do but its very VERY specific
press power
when te white led upper power flash on quiqkly relase power and press vol up..........
when the display make a very litle flash relase the vol buton
ENJOY AND GIVE THANKS
Hi, you are my knight in shining armour. You were right, it´s incredibly specific. You have to watch the white light above the power button and be plugged in into a socket. Nobody else mentioned the little white light, I was close to believe my tablet was defect.
Thank you very, very much.
than q
very use ful
ive tried it many times but still is stuck on sony logo
read my before coment
enjoy
I got to the Android selecting via the volume up/down page- but when I press the power button to select factory reset nothing happens.
Thanks!!!! It worked. For guys who dont know, you should pług your tan to the electricity. Then everything works fine
Yes. I had to try it about 10 times before it entered the "Rescue Mode". Don't opt for the rescue mode. You don't care about saving anything at this point. Press-"Skip". And it will go to full restore. Be patient. But the split second of both bottoms was hard.
Please see above comment.
It is similar to the hard reset of vaio laptops. That is, turning on and immediately pressing F-10 rapidly. It enters hard restore mode. But the tablet uses the pwr and + volume buttons together. Keep trying. My tablet works Fine now.
Make sure you're connected to power.
I know this is a long time ago, however just tried to start my xperia tablet as thought it was dead. Power and volume up button at same time ( charging led flashes twice) then I press power again and the white led lights up for about 1-2 seconds, I then press the up volume but no matter how long I hold the button down for there is nothing from the screen. Even if I keep pressing volume up button whilst pressing power again to get the white led, nothing happens.
This doesnt work
hello
it’s a working procedure, many thanks! Is there any way to update the android version to a more recent version above 4.0.3.?
Hello!!!! Thanks for your help, excellente procedure, easy if you follow carefully the steps =)
no avanza de la parte del logo de sony y cuando intento hacer el hard reste con los botones hago lo mismo de presionar el encendido y el de vol+ ala ves y cuando sale el logo de sony lo suelto pero no entra al sistema y no avanza y nos que hacer ayuda
es una modelo sgpt122mx/s
I already made the factory reset, but it still does not change the sony logo that I can do
ya logre hacer el reseteo de fabrica pero sige sin pasar del logo de sony que puedo hacer
does anyone know how to hard reset spg611 z3 compact tab/pc CB5A22ELMC serial . none of the above have worked .Ive managed to get it into safe mode but that’s all. PLZZZZ HELP. i have forgotten the password , there was a reset password option but know there is not.
After I reset my sony tab it still will not boot up it won't go passed the sony please help
thank you ‘tunerlezoart4everx’ its specific and working :)
hi man
press power
tunerlezoart4everx - 11-09-2015
Man how many minutes it take to open after reset
