This guide will show the steps for removing each speaker from the box and the procedure for removing all wires from the speakers.
Pull screen cover from the edges for removal. This will not require much effort.
Remove the seven 18.06mm PH1 screws.
Remove the crimps from the tweeter speaker.
If its not connected too tightly the crimps can be removed by hand pressure only.
Remove the crimps from the 12cm loudspeaker.
Remove the grommet using an object with a flat edge.
Feed the speaker cable through the front of the box.
crwdns2935229:05crwdne2935229:0
