Sony SRS-XB30 Bluetooth Chip Replacement
  1. Sony SRS-XB30 Bluetooth Chip Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To remove the speaker grill, insert the big spudger underneath it in each corner.
    • Work around the edges to pry the grill up and off.
  2. Sony SRS-XB30 Bluetooth Chip Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony SRS-XB30 Bluetooth Chip Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With the Sony logo facing towards you, use the medium spudger to lift the side plates from the internal frame.
    • This will need to be done on all four sides of the speaker to remove all four panels
    • This requires some effort because the adhesive is sticky.
  3. Sony SRS-XB30 Bluetooth Chip Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony SRS-XB30 Bluetooth Chip Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the four screws on the now exposed front panel.
    • Using the screwdriver with bit T7, unscrew each screw (15.0 mm long).
    In my speakers it was T8 size
    Filipe Silva - crwdns2934203:0crwdne2934203:0
    Mine was T9, looks like it migh vary
    diego perrig - crwdns2934203:0crwdne2934203:0
  4. Sony SRS-XB30 Bluetooth Chip Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Next, remove the four outer edge screws, located on each corner of the speaker. The outer edge of the speaker is a clear plastic.
    • Use the same T7 screwdriver head here.
    • Remove each of the four corner screws (15.0 mm long).
  5. Sony SRS-XB30 Bluetooth Chip Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With a little force, carefully lift the lid of the speaker.
    • Make sure that you do not pull on the wires.
  6. Sony SRS-XB30 Bluetooth Chip Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony SRS-XB30 Bluetooth Chip Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony SRS-XB30 Bluetooth Chip Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unclip the four wire connectors (that are attached to the speaker lid).
    • Disconnect the thin yellow wire (attached to the speaker lid) from its port.
  7. Sony SRS-XB30 Bluetooth Chip Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Separate the speaker lid from the bottom frame.
    • To prepare the speaker for the next step place the lid parallel to the frame.
  8. Sony SRS-XB30 Bluetooth Chip Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the two silver screws (9 mm) attached to the two LED-light-chips on the speaker lid.
    • Using the screwdriver with bit PH1, unscrew each screw.
  9. Sony SRS-XB30 Bluetooth Chip Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Separate the speaker lid entirely from the bottom frame.
    You have to remove de NFC circuit before the next step, or you wil broke the connection .
    Jaja - crwdns2934203:0crwdne2934203:0
    This would have been perfect to know BEFORE I ripped it...
    I didn't see this comment... F*CK!!!
    Kenneth Carlsson - crwdns2934203:0crwdne2934203:0
  10. Sony SRS-XB30 Bluetooth Chip Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the top screw (10 mm).
    • Use the screwdriver with bit T7.
  11. Sony SRS-XB30 Bluetooth Chip Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony SRS-XB30 Bluetooth Chip Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate and remove the three black screws (10.0 mm) within the internal frame. Use bit T7.
    • There are two screws on the left side of the white box and one to its right.
    What is the power circuit board name? Where it found?
    hiftekhar16 - crwdns2934203:0crwdne2934203:0
  12. Sony SRS-XB30 Bluetooth Chip Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slightly lift the white box with all the wires still attached.
    Before taking out the white plastic, remove the circuit pin on top, by the buttons, otherwise you will brake the conectios as I did!
  13. Sony SRS-XB30 Bluetooth Chip Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony SRS-XB30 Bluetooth Chip Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Take the big spudger and pry the black casing up from the circuit box.
  14. Sony SRS-XB30 Bluetooth Chip Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the blue film attached to the circuit box containing the charging port.
    • Detach the blue film from the box.
  15. Sony SRS-XB30 Bluetooth Chip Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Detach the yellow, black and red wires by pulling them directly up.
  16. Sony SRS-XB30 Bluetooth Chip Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony SRS-XB30 Bluetooth Chip Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the spudger along the battery edge and firmly hold the wires. Lift both sides up. The battery will pop out from its encasement.
  17. Sony SRS-XB30 Bluetooth Chip Replacement, Bluetooth Chip: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To save time, pry up and remove the top panel first.
  18. Sony SRS-XB30 Bluetooth Chip Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony SRS-XB30 Bluetooth Chip Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Take the spudger and pry under the plastic square that the Bluetooth chip is directly attached to.
    • This will separate the plastic square from the lid.
  19. Sony SRS-XB30 Bluetooth Chip Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the Bluetooth chip.
    Hi where could I bye the chip from your help would be appreciated
    Jan Malan - crwdns2934203:0crwdne2934203:0
Star Dragon
crwdns2935283:004/09/18crwdne2935283:0
669 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team S3-G1, Rowley Spring 2018 crwdns2935289:0Eastern Washington University, Team S3-G1, Rowley Spring 2018crwdne2935289:0
EWU-ROWLEY-S18S3G1
I'm pretty sure this is the nfc chip and not the Bluetooth chip
john may - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 39
crwdns2942667:0crwdne2942667:0 3,821
