Sony SRS-X55 Input Board Replacement
  1. Sony SRS-X55 Input Board Replacement, Input Board: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the six 9 mm screws on the bottom of the SRS-X55 and remove them using a Phillips head #2 screwdriver.
  2. Sony SRS-X55 Input Board Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony SRS-X55 Input Board Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a plastic spudger at the seam of the bottom panel and remove it from the rest of the speaker.
  3. Sony SRS-X55 Input Board Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony SRS-X55 Input Board Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony SRS-X55 Input Board Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the battery plug and remove it using a pair of tweezers.
  4. Sony SRS-X55 Input Board Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony SRS-X55 Input Board Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony SRS-X55 Input Board Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the two 3.5 mm screws on the bottom of the I/O board and remove them using a Phillips head #2 screwdriver.
  5. Sony SRS-X55 Input Board Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a plastic spudger to remove the I/O board from the speaker body.
  6. Sony SRS-X55 Input Board Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony SRS-X55 Input Board Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a plastic spudger into the seam of the metal speaker cover and pry it downward until it releases from the speaker body.
  7. Sony SRS-X55 Input Board Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony SRS-X55 Input Board Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the eight 8.9 mm screws on the face of the speaker assembly and remove them using a Phillips head #2 screwdriver.
  8. Sony SRS-X55 Input Board Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony SRS-X55 Input Board Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a plastic spudger underneath one of the tabs located on the front of the speaker assembly and gently raise the speaker assembly above the rest of the speaker.
    • Continue to the next step before attempting to lift the speaker assembly from the rest of the speaker entirely to avoid damaging internal wires.
  9. Sony SRS-X55 Input Board Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony SRS-X55 Input Board Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony SRS-X55 Input Board Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the two wire connections as shown underneath of the speaker assembly and unplug them using a pair of tweezers.
  10. Sony SRS-X55 Input Board Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the wire connecting the motherboard and the input board under the top panel of the speaker and remove it using a pair of tweezers.
  11. Sony SRS-X55 Input Board Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony SRS-X55 Input Board Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony SRS-X55 Input Board Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a plastic spudger into the seam at the edge of the top panel and gently pry it away from the rest of the speaker.
    • The spudger can be inserted laterally into the opening created by the spudger and slid along the top as shown to remove the panel in a single motion.
  12. Sony SRS-X55 Input Board Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the three 4.5 mm screws on top of the speaker input board and remove them using a Phillips head #2 screwdriver.
  13. Sony SRS-X55 Input Board Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony SRS-X55 Input Board Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony SRS-X55 Input Board Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a plastic spudger underneath the edge of the input board and gently pry it away from the rest of the speaker.
    Is this input board available in the market?
    Manoj Acharya - crwdns2934203:0crwdne2934203:0
    If yes, where and what shall I ask while visiting the market.
    I'm from Mumbai
Chris Sparzo
crwdns2935283:001/26/17crwdne2935283:0
351 crwdns2915208:0crwdne2915208:0
IUPUI, Team 2-3, Baechle Spring 2017 crwdns2935289:0IUPUI, Team 2-3, Baechle Spring 2017crwdne2935289:0
IUPUI-BAECHLE-S17S2G3
Where I can find a new input board for my srs-x55??
luc belair - crwdns2934203:0crwdne2934203:0
I want to buy the sony input board.. can u pls help me on this
prafulpu - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 1,056
