Sony SRS-X55 Button Circuit Board Replacement
  1. Sony SRS-X55 Button Circuit Board Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony SRS-X55 Button Circuit Board Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony SRS-X55 Button Circuit Board Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the six screw covers with a spudger.
    • Remove the six 11 mm Phillips screws from the bottom panel.
    • Remove the bottom panel of the speaker.
    Geez, they make it a 'challenge' to get those gaskets under the batt covers off.
    Don't make ant immediate plans....call your wife, you're gonna be a little late.
    Jim Malina - crwdns2934203:0crwdne2934203:0
    I need battery with board please help ??
    Kevin Ke - crwdns2934203:0crwdne2934203:0
  2. Sony SRS-X55 Button Circuit Board Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the battery cable from the motherboard.
    • Remove the battery.
    looks like 2 x 18650 batteries in a heatshrink sleeve..
    konanick - crwdns2934203:0crwdne2934203:0
    I need battery and board please
  3. Sony SRS-X55 Button Circuit Board Replacement, Speaker Panel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the speaker grill by pushing on the two tabs in the corners.
  4. Sony SRS-X55 Button Circuit Board Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the eight 0.5mm Phillips #1 screws from the speaker panel.
    Hello, do you know where I could find the speakers to replace at my personal audio system SRSx5 ?
    marcelogonc - crwdns2934203:0crwdne2934203:0
  5. Sony SRS-X55 Button Circuit Board Replacement, Button Circuit Board: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the flat side of the metal spudger, apply pressure to underside of the cover to loosen the adhesive and separate the cover from the top of the speaker.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
  6. Sony SRS-X55 Button Circuit Board Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the Phillips #00 screwdriver, pull out the three screws keeping the button board in place.
    Friend at least let us know the circuit model no. Offer equivalent
    Manoj Acharya - crwdns2934203:0crwdne2934203:0
  7. Sony SRS-X55 Button Circuit Board Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the button board from the speaker.
    PLEASE give me new PLET and BUTTON
    laladharmendralala - crwdns2934203:0crwdne2934203:0
Crosby Taylor
crwdns2935283:002/16/16crwdne2935283:0
213 crwdns2915208:0crwdne2915208:0
University of Alabama, Team 1-3, Sydow campbell Spring 2016 crwdns2935289:0University of Alabama, Team 1-3, Sydow campbell Spring 2016crwdne2935289:0
UA-SYDOW CAMPBELL-S16S1G3
My touch system has got stuck in audio in and sound mode when i press the switch on button it powers on. But ater that Although I press on the bluetooth pairing button it does not come on and i can use the set only in wired mode from tab to speaker also i cant manually switch off either.I have to let it idle to allow it to switch on on its own. The lights are on but touch is not responding its stuck in audio in and sound mode. Please advice what should I do please. I cant use the speaker in blue tooth mode. Regards ranil
Ranil - crwdns2934203:0crwdne2934203:0
Does anyone know if there is a schematic anywhere for the Sony SRS X55? I want to build a battery pack without the charge controller. Just charge 2 individual 18650 batts and put them in
faycoema - crwdns2934203:0crwdne2934203:0
I have no idea where to order the button board.
Tee Jay - crwdns2934203:0crwdne2934203:0
arvindpande2008 - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 3,308
