Sony SRS-X5 Speaker Replacement
  1. Sony SRS-X5 Speaker Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To gain access to the 6 bottom screws remove the following. Remove the adhered 4 corner foam pads on the bottom of the speaker using the blue plastic opening tool to reveal the screws underneath. Remove the adhered 2 center plastic squares.
    • Make sure the speaker is unplugged and powered down before doing any work on the device.
    Be consistent with vocabulary. For example, on the first step you used "foam pieces" and "pads" to identify the same thing and it may be confusing for some users.
    Yuri Borges - crwdns2934203:0crwdne2934203:0
  2. Sony SRS-X5 Speaker Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony SRS-X5 Speaker Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the six 6mm screws with a Phillips head #1 screwdriver.
    • Remove the bottom panel of the speaker.
  3. Sony SRS-X5 Speaker Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the battery by gently pinching the plastic end connected to the smaller board and pull away.
    • Remove the battery.
  4. Sony SRS-X5 Speaker Replacement, Speaker: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To remove the speaker grill, first push down slightly on the 2 plastic hook tabs to release them, then push the middle plastic screw tab out.
    not sure how to do this.
    some how the middle parts is hard to push
    Raffaello Sanzio - crwdns2934203:0crwdne2934203:0
    Remove the panel NOT by pushing or pulling the centre tab or you will break it. Instead, you’ll see two small tabs that must gently be pushed a little. Do not apply too much force. Once the grille comes loose pull it up. The upper side of the grille simply locks into place by moulded lips that fit into the top section of the product. Take care not to damage the now exposed loudspeakers.
    wim.1671 - crwdns2934203:0crwdne2934203:0
  5. Sony SRS-X5 Speaker Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the eight 0.5mm Phillips #1 screws from the speaker panel.
  6. Sony SRS-X5 Speaker Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony SRS-X5 Speaker Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the plastic opening tool, flip open the speaker panel.
  7. Sony SRS-X5 Speaker Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony SRS-X5 Speaker Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony SRS-X5 Speaker Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unplug the 6-pin speaker connector and 2-pin microphone connector from the motherboard by squeezing the sides of the plastic ends.
    where can i buy a spare speaker????????
    bollebaab-bouwer - crwdns2934203:0crwdne2934203:0
    Hey lovely ifixit folk. Could you do us the favour of reading off the first picture the details on the back of the centre driver? I can see from the picture that it say 4ohm but can’t read beyond that.
    I’m trying to repair mine and need to replace that centre driver with the closest spec equivalent.
    Benji Greig - crwdns2934203:0crwdne2934203:0
crwdns2935229:05crwdne2935229:0
Carrie Cutler
crwdns2935283:009/28/16crwdne2935283:0
500 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team 2-6, Mathisen Fall 2016 crwdns2935289:0Eastern Washington University, Team 2-6, Mathisen Fall 2016crwdne2935289:0
EWU-MATHISEN-F16S2G6
crwdns2947412:010crwdne2947412:0
Help :)
Where can i buy a New speaker ?
Best regard Olav
olavfberge - crwdns2934203:0crwdne2934203:0
lol everywhere i go to find the replacement speaker i find more people trying to find it…. really want to fix my speaker..ffs
bollebaab-bouwer -
is there not a single soul that know the answer, why is this so hard to find out. im starting a company in loose speaker cones
bollebaab-bouwer -
Many thanks. Now I just need to find a replacement speaker!
Lesley Packwood - crwdns2934203:0crwdne2934203:0
4yrs still know answer, joke
Glenville Caesar -
Has anyone found a source for replacement speakers compatible with this device?
tom voll - crwdns2934203:0crwdne2934203:0
And you guessed it , where the !&&* do you find one of these woofers to replace the crapped out original . At this point my x5 is pretty much useless and only just out of warranty.
Can any one please suggest a replacement from any where on this earth ???????
jasonandleah - crwdns2934203:0crwdne2934203:0
138/5000
guys, you can repair the speaker cone with neoprene glue, put a layer on the cut, let dry all night and go.
benjaminbetancur - crwdns2934203:0crwdne2934203:0
Neither Sony nor their parts distributors have replacement parts for the SRS-X5, except for the 12.5V power unit. The customer service agent I spoke to told me that this was a repair by replacement model. Besides that they could not tell me if any parts (in this case the speakers) were used in any other Sony products that may have available stock. I’m checking eBay for second hand parts and then avoiding Sony products. I’m frustrated at the idea of throwing out an otherwise decent product for lack of a $5 part.
Narduzzi - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 60
crwdns2942667:0crwdne2942667:0 4,408
