Sony SRS-X5 Bluetooth Replacement
  1. Sony SRS-X5 Bluetooth Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To gain access to the 6 bottom screws remove the following. Remove the adhered 4 corner foam pads on the bottom of the speaker using the blue plastic opening tool to reveal the screws underneath. Remove the adhered 2 center plastic squares.
    • Make sure the speaker is unplugged and powered down before doing any work on the device.
    Be consistent with vocabulary. For example, on the first step you used "foam pieces" and "pads" to identify the same thing and it may be confusing for some users.
    Yuri Borges - crwdns2934203:0crwdne2934203:0
  2. Sony SRS-X5 Bluetooth Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony SRS-X5 Bluetooth Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the six 6mm screws with a Phillips head #1 screwdriver.
    • Remove the bottom panel of the speaker.
  3. Sony SRS-X5 Bluetooth Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the battery by gently pinching the plastic end connected to the smaller board and pull away.
    • Remove the battery.
  4. Sony SRS-X5 Bluetooth Replacement, Speaker: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To remove the speaker grill, first push down slightly on the 2 plastic hook tabs to release them, then push the middle plastic screw tab out.
    not sure how to do this.
    some how the middle parts is hard to push
    Raffaello Sanzio - crwdns2934203:0crwdne2934203:0
    Remove the panel NOT by pushing or pulling the centre tab or you will break it. Instead, you’ll see two small tabs that must gently be pushed a little. Do not apply too much force. Once the grille comes loose pull it up. The upper side of the grille simply locks into place by moulded lips that fit into the top section of the product. Take care not to damage the now exposed loudspeakers.
    wim.1671 - crwdns2934203:0crwdne2934203:0
  5. Sony SRS-X5 Bluetooth Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the eight 0.5mm Phillips #1 screws from the speaker panel.
  6. Sony SRS-X5 Bluetooth Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony SRS-X5 Bluetooth Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the plastic opening tool, flip open the speaker panel.
  7. Sony SRS-X5 Bluetooth Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony SRS-X5 Bluetooth Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony SRS-X5 Bluetooth Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unplug the 6-pin speaker connector and 2-pin microphone connector from the motherboard by squeezing the sides of the plastic ends.
    where can i buy a spare speaker????????
    bollebaab-bouwer - crwdns2934203:0crwdne2934203:0
    Hey lovely ifixit folk. Could you do us the favour of reading off the first picture the details on the back of the centre driver? I can see from the picture that it say 4ohm but can’t read beyond that.
    I’m trying to repair mine and need to replace that centre driver with the closest spec equivalent.
    Benji Greig - crwdns2934203:0crwdne2934203:0
  8. Sony SRS-X5 Bluetooth Replacement, Bluetooth: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony SRS-X5 Bluetooth Replacement, Bluetooth: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the cord connected to the motherboard by squeezing the plastic sides.
  9. Sony SRS-X5 Bluetooth Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently tug on the plastic ribbon connected to the bottom side of the speaker to unplug it.
  10. Sony SRS-X5 Bluetooth Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the motherboard.
    Good disassembly directions, but titlle is Bluetooth replacement. No parts needed? How do we replace bluetooth part?
    Mark Savage - crwdns2934203:0crwdne2934203:0
Jeffrey Yalung
crwdns2935283:009/28/16crwdne2935283:0
460 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team 2-6, Mathisen Fall 2016 crwdns2935289:0Eastern Washington University, Team 2-6, Mathisen Fall 2016crwdne2935289:0
EWU-MATHISEN-F16S2G6
crwdns2942667:0crwdne2942667:0 2,142
