On this guide, the aim is to teach how to disassemble the Sony SRS-X3 bluetooth speaker in order to replace the speakers in the unit. This teardown is fairly simple, and only requires two tools. This speaker replacement is being completed because of a humming sound coming from the unit when music is being played.
Remove the rubber feet on the bottom of the device.
Remove the 6 silver screws with a Phillips #1 screwdriver.
Remove the bottom plastic cover of speaker.
Hola este yo tengo un parlante asi pero no kiere gargar
Remove the two screws holding the battery pack with the Phillips #1 screwdriver.
Remove the battery back with a spudger.
Remove the three screws using a Phillips #1 screwdriver.
Remove the green circuit board and the battery pack.
Pop off the front speaker face (dark grey with little holes) by pushing out 3 tabs where screws were previously located and sticking the spudger in the crack where grey speaker face meets the outer shell.
You may really have to pry on this part; it is not easy to remove and will pop out when released.
Remove the eight black screws with a Phillips #1 screwdriver.
Remove the front face by prying the two black tabs using a spudger.
Remove the speaker wires from each speaker (2 wires per speaker) and take the speakers out of the device.
Remove the speakers from the device.
Where would I get the new speakers from tho? Thanks a lot
Where I can buy one speaker as a spare part?
I would also like to know where I can get a replacement speaker
This SRS X3 cannot be used with the dc in 5v plugged, how can i do to make it work continuously with the charge cable? It have to be hacked? thanks
