The guide will demonstrate the steps necessary to replace a bad battery charging port with a new one. The speaker will be disassembled from a fully assembled condition by following the necessary steps listed in this guide to replace the faulty charging port. For this repair guide only a Phillips screwdriver and the replacement board are necessary. This replacement is very straight forward and very simple for a beginner.
Remove the 6 10mm Philips head screws shown, using a PH1 screwdriver
Remove the 5 8mm Philips head screws shown. These are holding the battery and the green circuit board in.
Lift the battery pack and circuit board out of the housing and locate the wires and ribbon connector shown in the figure.
Remove the ribbon connector and the connector from the battery pack (Note: These connectors are not easy to remove. Force may be necessary but the connectors are durable)
After the connections are remove you are free to replace the circuit board.
crwdns2935229:05crwdne2935229:0
crwdns2947412:012crwdne2947412:0
Bradley, this is a SONY 40BKB537U-CNF2G board….where can I get one? The mini charge port is bad on mine and v difficult to replace.
Thanks
Where can I buy the whole circuit board to replace the Charging port
Sony Mini speaker SRS - X3
40BKB537U - CNF2G
charging port
Morgan -
Where can I buy circuit board To replace charging port Sony Mini speaker SRS - X3
40BKB537U-CNF2G
Morgan -
Hi Michael, did you find a replacement board? I need to replace mine as well.
I have all the part of this speaker. Email me to negotiate! Kennyportillo99@gmail.com
