Sony Reader Wi-Fi PRS-T3 E-Ink screen Replacement
  1. Sony Reader Wi-Fi PRS-T3 E-Ink screen Replacement, Disassembling: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Reader Wi-Fi PRS-T3 E-Ink screen Replacement, Disassembling: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Reader Wi-Fi PRS-T3 E-Ink screen Replacement, Disassembling: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Detach the back cover from the e-reader
    • Remove the black sticker, uncovering three additional screws. The sticker comes loose quite easy.
    • Unscrew all 10 screws (length 3.2mm).
    • Now take a spudger, and start opening the case at the top. There are four retaining clips at each side.
  2. Sony Reader Wi-Fi PRS-T3 E-Ink screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Under the cover you'll find many interesting things.
  3. Sony Reader Wi-Fi PRS-T3 E-Ink screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew these 5 screws (length 4.3mm) . They hold the front bezel (white or black part of the main body).
    • There are other screws that hold the motherboard (10×, 1.8mm) to the grey back plate. You do not need to remove them, unless you want to remove the electronics board (for example to prevent damage when cleaning the back plate in a later step).
  4. Sony Reader Wi-Fi PRS-T3 E-Ink screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Reader Wi-Fi PRS-T3 E-Ink screen Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Reader Wi-Fi PRS-T3 E-Ink screen Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully unplug buses. For the screen bus. Simple pull it from connector. For the hard keys bus . First, open the connector by hook it from below. Then it'll be easy to unplug the bus.
  5. Sony Reader Wi-Fi PRS-T3 E-Ink screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Reader Wi-Fi PRS-T3 E-Ink screen Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully unglue the Wifi antenna.
  6. Sony Reader Wi-Fi PRS-T3 E-Ink screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Reader Wi-Fi PRS-T3 E-Ink screen Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Now we need to remove a white cover. It helds by clips around the body. Please, pay attention to hooks in red ellipses on the photo. On the second photo you may see detached white cover.
  7. Sony Reader Wi-Fi PRS-T3 E-Ink screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Reader Wi-Fi PRS-T3 E-Ink screen Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Reader Wi-Fi PRS-T3 E-Ink screen Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew screws marked by red cicles.
    • Carefully unplug a bus
    • Be careful, do not lose this tiny thing!
    • Remove black frame. It's attached to the screen by double sided tape
  8. Sony Reader Wi-Fi PRS-T3 E-Ink screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Reader Wi-Fi PRS-T3 E-Ink screen Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Reader Wi-Fi PRS-T3 E-Ink screen Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use any suitable knife to detach broken screen from metal plate. Please, be very careful. Do not hurt yourself!
    • After you did this. You need to clean metal plate from the remnants of glue and double sided tape.
  9. Sony Reader Wi-Fi PRS-T3 E-Ink screen Replacement, Screen assembling: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Reader Wi-Fi PRS-T3 E-Ink screen Replacement, Screen assembling: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Reader Wi-Fi PRS-T3 E-Ink screen Replacement, Screen assembling: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Take a new screen. Apply double sided tape on back side.
    • Remove protective film from the screen
    • Put the screen into the black frame. Upper side of the screen should touch upper side of the frame.
  10. Sony Reader Wi-Fi PRS-T3 E-Ink screen Replacement, Gluing  the screen to the surface: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Reader Wi-Fi PRS-T3 E-Ink screen Replacement, Gluing  the screen to the surface: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully join the screen in a black frame with the metal plate.
    • Continue assembling in a reverse order
crwdns2935229:08crwdne2935229:0
mrdkonst
crwdns2935283:004/02/15crwdne2935283:0
223 crwdns2915208:0crwdne2915208:0
crwdns2947412:020crwdne2947412:0
This an incredibly useful guide. I have the new screen, but I have asked and have not gotten an answer about what double-sided tape is used to attach the new screen to the body. Could someone supply this information pleasae.
kgarnjost - crwdns2934203:0crwdne2934203:0
You may use any double-sided tape you'll find in a shop. I used a 0.5 mm tape or thinner. I found it in a Stationary shop.
mrdkonst -
Is the ED060XC5(LF)C1 screen, the same quality and matte as the original one? I don't trust asian sellers so much, but the only one that I found on internet is this one.
http://es.aliexpress.com/item/100-new-or...
Ale - crwdns2934203:0crwdne2934203:0
In my case it has the same quality. I bought it on Aliexpress also.
mrdkonst -
After installing replacement screen the touch functionallity does not work, screen itself seems to work but you cannot make any touch selections, does anyone has an idea?
hansbergman767 - crwdns2934203:0crwdne2934203:0
датчики сенсора находятся на материнской плате устройства по периметру. если они не становятся на свое место относительно экрана, сенсор не работает.
Yury -
Thank you so much!! I fix my beloved reader thanks to your guide!!
Joceline Stephani - crwdns2934203:0crwdne2934203:0
Hello! Did you replace display + touchscreen or only display? Does touchscreen works after all operations?
Sergey Bogomolov - crwdns2934203:0crwdne2934203:0
Hi! Here we have only a display for replace. Touch screen had been organised on some kind of infrared backlight. You can see IR diods and sensors around metal plate. So, I think, it something wrong with bus connection. Check if you made reassemble in correct way.
mrdkonst -
After replacing the screen everything seems to be working. However, after a few page flipping it became to be "junk". It seems to have the additional service nastnoyki help to cope with it. Maybe someone heard about it?
Yury - crwdns2934203:0crwdne2934203:0
Thank you for your tutorial. After replacing the screen, the screen looks like it's working, but the buttons don't work and touch screen doesn't work. Could you please tell me what do do next? What can I try? Both the screen bus and the hard keys bus are in place, as indicated on the pictures. Thank you!
Alice - crwdns2934203:0crwdne2934203:0
Hi,
Unfortunately, I don't know what to suggest to you. Please double check bus connections.
mrdkonst -
Thanks for this useful tutorial. After the change of my screen I've just lost temporarily the touch fonctionallity. All is ok after a reset and waiting time. Time for electrical power to activate all the components of the new screen ?
For the step 8, it's easier t detach old screen after heating (not too mutch) the screen with an hair dryer. Finaly, I remove the old glue traces with aceton.
Archambeau - crwdns2934203:0crwdne2934203:0
I've allmost fixed my t3s, but one trace of the hard keys and charging flex cable got broken.
Any suggestions on what cable to buy to replace it?
koffieleut - crwdns2934203:0crwdne2934203:0
Removing the fragile plactic frames is tricky. Removing the screen from the metal back was a pain. Glass part came of in thousand pieces. No injuries though fortunately. Reassembling was a breeze. Yes it works again. A real victory on my part! Thanks for the great tutorial!
Jaap - crwdns2934203:0crwdne2934203:0
Can i replace the LCD screen with backlight ? If yes which model do you think suitable and able to retain all functionality , do i need to replace the battery too ?
Karelyn Yep - crwdns2934203:0crwdne2934203:0
no, you cannot. This model only works with a reflective e-paper screen (not LCD)
Uwe Zimmermann -
Thank you very much. I had ordered the replacement screen 1 1/2 years ago but never took the time to fix it. Today I got mad at my newer Tolino reader which refuses to open many of my epub-files that I finally got around to try the repair.
Opening the device was easy, replacement was easy, but the original glue behind the screen! What a mess. This glue stuck to everything, my fingers, my knives. I was hoping to get the screen off in bigger chunks, but to no avail. I had to crumble it into tiny bits, remove the glue with combinations of acetone, thinner, alcohol and mechanical force. I was lucky that the infrared touch function wasn’t getting too dirty around the edges.
Now let’s hope that the battery didn’t fare too bad during the long rest, otherwise I will have to open it soon again…
Uwe Zimmermann - crwdns2934203:0crwdne2934203:0
Does anybody can shed some light on this infrared touchscreen mechanism? I succesfully swapped the screen, but touch functionality doesn't work.
I found out that if I press the outer frame and the back cover very hard in the lower right edge, touchscreen seems to work, but I have no idea what went wrong here. And why pressing the edge seems to help.
Ok, I could use the reader like that but it's too frustrating. Before I throw it away, it would be interesting to know what went wrong here and if this is fixable somehow now that the screen is already placed in the bacl frame and on the aluminium (I'm sure trying to remove it will completely break and destroy it).
I don't see any space between the inner black frame and the screen, so how does this work with the IR-beams? I also tried to check it with a mobile phone camera to find out if there are some IR-beams present, but I can't see anything..
test test - crwdns2934203:0crwdne2934203:0
Hi @testtest55662, As @yuryza described above, please check if screen and frame is assembled in right way.
mrdkonst -
crwdns2936753:030crwdne2936753:0 43
crwdns2942667:0crwdne2942667:0 8,607
