Unscrew the screws on the top of the radio.
Open the CD and cassette doors and remove the screws in the compartments.
Flip the radio upside down and remove the battery cover. Unscrew the one screw below the batteries.
Remove the top of the radio enough to access the wires for removal.
Remove all of the wires that are connected to both the circuit board and the underside of the top of the radio by pulling them where they are connected
Unscrew the screws on the top right and top left of the back side of the buttons of the radio.
Pull out the buttons of the radio from the inside.
Pull out the audio in jack which is located on the right side of the radio directly below where the buttons are.
Remove the audio in jack from the circuit board by pulling on the wires where they are connected to the board.
Connect the new audio in jack wires to the circuit board where the old one used to be.
Insert the new audio in jack into the hole on the back side of the front face of the radio.
En français cela serrais mieux
Vielen lieben Dank für diese Info. Habe den Kasettenspieler erfolgreich repariert. Freut mich riesig. Danke danke!!! :-)
