This guide will teach you how to replace your motherboard in your Sony device.
            Use a Phillips #00 screwdriver to remove the four (4) screws on the back of the device.
            If the screws strips or is previously stripped, refer to the stripped screw repair guide.
            Battery is the rectangular and silver object in the center of device.
            Remove battery with finger by prying at the rear.
            If unable to remove battery, pry out using spudger.
            Unscrew the 3 (three) screws holding the bracket in place.
            Then remove the bracket by prying one end up.
   crwdns2935267:0crwdne2935267:0Tweezers$4.99-
            With tweezers, unplug the ribbon cable from the white connector.
            Remove motherboard from the device by pulling upward gently, with fingers or tweezers.
            Gently push out on these two clips holding the LCD to the motherboard
            Once you have the first two off, ever so carefully, push the LCD towards the remaining two clips.
            Undo the ribbon cable attached between the motherboard and screen by prying up black tab which holds the cable, using spudger. (See pictures)
            Remove the screen from the motherboard.
Hello
Thank you for your tutorial.
My question is about the rubber cap of the push button
Can it be changed? Spare part ?
Regards
