Sony Pulse Elite Edition Motherboard Replacement
  1. Sony Pulse Elite Edition Motherboard Replacement, Identifying Earpiece: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the left side designation on the headband-earpiece junction.
    • The battery is in the right earpiece.
    • The motherboard is in the left earpiece.
  2. Sony Pulse Elite Edition Motherboard Replacement, Ear Cushion Removal: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Pulse Elite Edition Motherboard Replacement, Ear Cushion Removal: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pull around the perimeter of the left ear cushion until it comes off.
  3. Sony Pulse Elite Edition Motherboard Replacement, Outer Ear Rim Removal: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Pulse Elite Edition Motherboard Replacement, Outer Ear Rim Removal: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the PH00 Screwdriver to remove the three Phillips 6mm screws around the perimeter of the ear cup.
    • Gently pull the outer ear rim off of the headset assembly.
    • Harsh removal may cause permanent damage to the speaker wires.
  4. Sony Pulse Elite Edition Motherboard Replacement, Remove Speaker Housing: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using tweezers, gently pry the red and black speaker wires from the attached socket.
  5. Sony Pulse Elite Edition Motherboard Replacement, Unscrew Motherboard Brackets: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the Phillips #00 screwdriver, remove the four Phillips 5 mm screws from the two motherboard brackets.
    • Keep the two brackets and screws in a safe place.
  6. Sony Pulse Elite Edition Motherboard Replacement, Remove the Wires: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using tweezers, unclip the blue, white, and red wire harness from the motherboard. This harness is for the microphone.
    • Using the tweezers, unclip the red and black wire harness from the motherboard. This harness is for the speakers.
    • Make sure all wire harnesses are completely unclipped prior to motherboard removal. Failure to unclip completely risks permanent damage to the headset.
  7. Sony Pulse Elite Edition Motherboard Replacement, Initial Motherboard Removal: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a finger, gently tug up on the motherboard.
    • Make sure to only lift the motherboard up gently as there are still wires connecting the motherboard to the ear piece.
    • Try and lift the motherboard up straight, as it will catch on the screw mounts otherwise.
  8. Sony Pulse Elite Edition Motherboard Replacement, Fixed Wire Removal: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Pulse Elite Edition Motherboard Replacement, Fixed Wire Removal: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using wire cutters, cut all of the permanent wires from the motherboard.
    • Strip the wires on the ear piece portion about a quarter of an inch from their cut ends.
    • These will need need to be soldered to the new motherboard, so it will be easiest to cut the wires, 1/2" away from the motherboard.
  9. Sony Pulse Elite Edition Motherboard Replacement, Solder New Motherboard: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Strip the wires on the ends of the new motherboard wires about a half inch from the end.
    • Solder each individual wire from the new motherboard to the corresponding wire on the ear piece.
    • Completely wrap each solder joint with electrical tape so that the exposed wires only contact their corresponding wires.
    • Unintentional contact of non-corresponding wires can result in electrical fire and the failure of the device.
    Where can i buy the motherboard for the sony pulse elite headset….??????
    king khan - crwdns2934203:0crwdne2934203:0
Chris Echter
crwdns2935283:001/29/15crwdne2935283:0
865 crwdns2915208:0crwdne2915208:0
Would you by any chance know the part number for the motherboard?
Nelson Furtado - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 23
crwdns2936753:030crwdne2936753:0 69
crwdns2942667:0crwdne2942667:0 4,120
