Sony PlayStation Camera Microphone Array Replacement
  1. Sony PlayStation Camera Microphone Array Replacement, Microphone Array: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony PlayStation Camera Microphone Array Replacement, Microphone Array: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Separate the camera from the camera stand to gain access to the bottom of the camera.
  2. Sony PlayStation Camera Microphone Array Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony PlayStation Camera Microphone Array Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With the PH000 sized screwdriver, remove the two 6.5mm Phillips #000 screws located under the stand connection point, where the cable enters the case.
  3. Sony PlayStation Camera Microphone Array Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using tweezers, remove the cap holding the cable grommet in place.
  4. Sony PlayStation Camera Microphone Array Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the tweezers, remove both poly-carbonate lens coverplates.
    • Lift the coverplates slowly, to ensure they do not crack, or break.
  5. Sony PlayStation Camera Microphone Array Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony PlayStation Camera Microphone Array Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the PH0 sized screwdriver, remove two 3.2mm Phillips #0 screws, located under the coverplates.
  6. Sony PlayStation Camera Microphone Array Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using extreme care, separate the front of the case, from the back with a metal spudger, or pry tool. The case will scratch easily.
    • The case joints can be hard to spot. They appear as a very fine line in the plastic. Start with light pressure until the seam parts, allowing the pry tool to work.
  7. Sony PlayStation Camera Microphone Array Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony PlayStation Camera Microphone Array Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the PH0 sized screwdriver, remove the four 4.5mm Phillips #0 screws securing the circuit assembly to the device housing.
  8. Sony PlayStation Camera Microphone Array Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony PlayStation Camera Microphone Array Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony PlayStation Camera Microphone Array Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the motherboard and frame from the plastic housing.
    • Disconnect the camera cable from the motherboard.
  9. Sony PlayStation Camera Microphone Array Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony PlayStation Camera Microphone Array Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the PH0 sized screwdriver, remove the six 4.2mm Phillips #0 screws securing the motherboard to the metal frame.
  10. Sony PlayStation Camera Microphone Array Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony PlayStation Camera Microphone Array Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a plastic opening tool, disconnect the microphone array connector from the motherboard.
  11. Sony PlayStation Camera Microphone Array Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony PlayStation Camera Microphone Array Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony PlayStation Camera Microphone Array Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using fine point tweezers, grab hold of each microphone, one at a time, and lift from the plastic frame.
    • Using care to not damage the wires, remove microphone array from the retaining tabs on the plastic frame.
Joshua Gates
crwdns2935283:002/15/17crwdne2935283:0
268 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 5-5, Passmore Spring 2017 crwdns2935289:0USF Tampa, Team 5-5, Passmore Spring 2017crwdne2935289:0
USFT-PASSMORE-S17S5G5
crwdns2942667:0crwdne2942667:0 7,335
