Remove the base by pushing in the button and sliding out the unit.
Remove USB port cover from back plate with a metal spudger.
With the Phillips #02 screwdriver, remove the six 6 mm length x 6 mm head screws from the back plate.
With the Phillips #02 screwdriver, remove the ten 6 mm length x 8 mm head screws from the back plate.
Remove back plate with a plastic opening tool by slowing prying around the entire plate.
Once separated the plate easily lifts off.
I got a used display that for some reason came with no screws on the back panel. Can you tell me exactly what type those 6x6mm and 6x8mm screws are? Especially wary since you said the thread sizes are different
