This repair may be needed if your device functions properly, but the indicator lights do not work.
Remove the base by pushing in the button and sliding out the unit.
Remove USB port cover from back plate with a metal spudger.
With the Phillips #02 screwdriver, remove the six 6 mm length x 6 mm head screws from the back plate.
With the Phillips #02 screwdriver, remove the ten 6 mm length x 8 mm head screws from the back plate.
Remove back plate with a plastic opening tool by slowing prying around the entire plate.
Once separated the plate easily lifts off.
With the Phillips #02 screwdriver, remove the two 5mm length x 5mm head screws located on the left and right side of the light bar board.
Remove the light bar by depressing the tab on the white data connector.
