Sony PS-LX300USB Drive Belt Replacement
  1. Sony PS-LX300USB Drive Belt Replacement, Drive Belt: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony PS-LX300USB Drive Belt Replacement, Drive Belt: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the rubber mat, and put it to the side. It should be easy to remove, because it simply rests on a metal platter without anything securing it down.
  2. Sony PS-LX300USB Drive Belt Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the platter so that the motor pulley can be seen through one of the two outer holes in the platter.
    • If the drive belt is hooked around the motor pulley, unhook it.
    • When reassembling to device, don't forget to hook the new drive belt to the motor pulley.
  3. Sony PS-LX300USB Drive Belt Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grasping the platter by its two inner holes, lift it upwards.
    • Removing the platter may take a small amount of force. If the pulley is unhooked and the tone arm is safely to the side, don’t fear using a small amount of force in lifting the platter.
    • If you haven’t yet unhooked the drive belt, the motor pulley and the belt could sustain damage.
  4. Sony PS-LX300USB Drive Belt Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony PS-LX300USB Drive Belt Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Peel the drive belt from the inner ridge of the metal platter and put it to the side.
    • Sometimes, the drive belt can fall off the platter during deconstruction. If this is the case, simply take it out of the device wherever it is.
crwdns2935229:018crwdne2935229:0
Michelle Jakab
crwdns2935283:009/27/17crwdne2935283:0
606 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S8-G3, Banghart Fall 2017 crwdns2935289:0Cal Poly, Team S8-G3, Banghart Fall 2017crwdne2935289:0
CPSU-BANGHART-F17S8G3
Thank you for posting this! My belt slipped and I could not figure this out thanks to you I saw how simple a process the repair. Many times thank you
Jeanine Haven - crwdns2934203:0crwdne2934203:0
Thank you for this post. I freaked out when belt became detached. I had moved turntable several times to resolve a connection issue and OOPS! Very concise instructions with clear pictures. Awesome!!
Eric Doner - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 144
crwdns2942667:0crwdne2942667:0 19,573
