Sony NWZ-E473 Front Button Replacement
  1. Sony NWZ-E473 Front Button Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 screwdriver to unscrew the two 5 mm screws located on the bottom of the back of the device.
  2. Sony NWZ-E473 Front Button Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a plastic opening tool to loosen the bottom portion of device.
  3. Sony NWZ-E473 Front Button Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a plastic opening tool to loosen the top panel of the device.
  4. Sony NWZ-E473 Front Button Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the two 3 mm screws located on the portion under the top panel of the device.
  5. Sony NWZ-E473 Front Button Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony NWZ-E473 Front Button Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony NWZ-E473 Front Button Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the back plate from the device.
  6. Sony NWZ-E473 Front Button Replacement, Battery: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony NWZ-E473 Front Button Replacement, Battery: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Peel back the layer of tape along with the processor, which is located just below the battery, using the tweezers and the spudger.
  7. Sony NWZ-E473 Front Button Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony NWZ-E473 Front Button Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide a prying tool underneath the top portion of the battery and lift it from the case.
  8. Sony NWZ-E473 Front Button Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the stickers from the battery terminals, which are on the underside of the battery.
  9. Sony NWZ-E473 Front Button Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a soldering iron to remove the wires from the red and the black terminals.
  10. Sony NWZ-E473 Front Button Replacement, Screen: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a nylon spudger or tweezers to remove the plastic USB cover.
  11. Sony NWZ-E473 Front Button Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 screwdriver to unscrew two 2 mm screws located on the top corners of the device.
  12. Sony NWZ-E473 Front Button Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a nylon spudger or tweezers to remove the plastic protective plate at the top of device.
  13. Sony NWZ-E473 Front Button Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony NWZ-E473 Front Button Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the plastic protective frame located over the motherboard with tweezers and a spudger.
  14. Sony NWZ-E473 Front Button Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove screen connection from motherboard using tweezers and spudger.
  15. Sony NWZ-E473 Front Button Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove two 3 mm screws at the bottom sides and two 1 mm screws at top sides of the device.
  16. Sony NWZ-E473 Front Button Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony NWZ-E473 Front Button Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #00 screwdriver to unscrew two 2 mm screws, and remove the motherboard from the device with tweezers and a plastic opening tool.
  17. Sony NWZ-E473 Front Button Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony NWZ-E473 Front Button Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the metal shielding plate from the front panel with tweezers or a plastic opening tool.
  18. Sony NWZ-E473 Front Button Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony NWZ-E473 Front Button Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a plastic opening tool to remove the screen from metal back plate.
  19. Sony NWZ-E473 Front Button Replacement, Front Button: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Ensure that button connection is completely separated from the buttons.
  20. Sony NWZ-E473 Front Button Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony NWZ-E473 Front Button Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony NWZ-E473 Front Button Replacement: crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove buttons from front display panel by pushing button display from the front of the device
Matthew Hintz
crwdns2935283:001/16/15crwdne2935283:0
330 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 17-6, Watkins Winter 2015 crwdns2935289:0USF Tampa, Team 17-6, Watkins Winter 2015crwdne2935289:0
USFT-WATKINS-W15S17G6
crwdns2942667:0crwdne2942667:0 1,936
