Removing the lens mount is a quick process that is fully outlined by this guide.
            If the camera is on, rotate the power switch on top of the camera counterclockwise to turn the camera off.
            Flip the camera over such that the power switch points down.
            Slide the switch on the bottom of the camera grip towards the lens to open the battery door.
            With the battery door open, push the blue lever in the battery compartment to release the battery.
            To the left of the battery compartment, the SD card needs to be pushed down slightly with your fingers, which will cause the card to eject.
            Pull the card out with your fingers.
            First, turn the camera upside down.
            Press the button located next to silver lens mount and rotate the lens counterclockwise.
            Pull the lens away from the camera body.
            With the front of the camera facing you, remove the four silver #00 Phillips screws from the metal lens mount.
            Remove these three layers from the lens mount with your finger or by turning the camera face down.
            Remove the two newly visible #00 screws within the metal ring.
            Remove the final metal ring from the mount.
crwdns2935229:05crwdne2935229:0
