Sony NEX-7 Lens Mount Replacement
crwdns2869540:0crwdne2869540:0: 3,3 B
3
19
98
3.273
crwdns2959984:0crwdne2959984:0: 5
crwdns2959974:05crwdne2959974:0
crwdns2959986:0crwdne2959986:0: 1
crwdns2959980:01crwdne2959980:0
crwdns2955944:0crwdne2955944:0: 5 - 10 crwdns2931279:0crwdne2931279:0
Removing the lens mount is a quick process that is fully outlined by this guide.
    1. Sony NEX-7 Lens Mount Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony NEX-7 Lens Mount Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • We need to turn off the camera because we are removing components that could get damaged if the power is still on.
      • If the camera is on, rotate the power switch on top of the camera counterclockwise to turn the camera off.
    2. Sony NEX-7 Lens Mount Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Flip the camera over such that the power switch points down.
      • Slide the switch on the bottom of the camera grip towards the lens to open the battery door.
    3. Sony NEX-7 Lens Mount Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • With the battery door open, push the blue lever in the battery compartment to release the battery.
    1. Sony NEX-7 Lens Mount Replacement, SD card: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • To the left of the battery compartment, the SD card needs to be pushed down slightly with your fingers, which will cause the card to eject.
      • Pull the card out with your fingers.
    1. Sony NEX-7 Lens Mount Replacement, Lens: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony NEX-7 Lens Mount Replacement, Lens: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • First, turn the camera upside down.
      • Press the button located next to silver lens mount and rotate the lens counterclockwise.
      • Pull the lens away from the camera body.
      • After removing the lens, replace the lens or attach the body cap as soon as possible to prevent damage to the shutter.
    1. Sony NEX-7 Lens Mount Replacement, Lens Mount: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • With the front of the camera facing you, remove the four silver #00 Phillips screws from the metal lens mount.
    2. Sony NEX-7 Lens Mount Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove these three layers from the lens mount with your finger or by turning the camera face down.
    3. Sony NEX-7 Lens Mount Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the two newly visible #00 screws within the metal ring.
    4. Sony NEX-7 Lens Mount Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the final metal ring from the mount.
crwdns2935229:05crwdne2935229:0
Jay Miley
crwdns2935283:004/22/14crwdne2935283:0
5.514 crwdns2915208:0crwdne2915208:0
crwdns2935297:013crwdne2935297:0
Cal Poly, Team 10-55, Amido Spring 2014 crwdns2935289:0Cal Poly, Team 10-55, Amido Spring 2014crwdne2935289:0
CPSU-AMIDO-S14S10G55
crwdns2935297:0168crwdne2935297:0
crwdns2936753:07crwdne2936753:0 19
crwdns2936753:030crwdne2936753:0 98
crwdns2959996:0crwdne2959996:0 3,273
