The removal of the motherboard involves removing a significant portion of the rear casing, the internal casing, and the removal of component connections. Care and safe handling is advised in this guide.
Open the battery pack door by moving the slider to "OPEN".
Remove the 3.25 mm silver screw inside the battery pack with a Phillips screwdriver.
Remove the 3.25 mm exterior screw with a Phillips screwdriver.
Use the spudger to raise the corner of the case from the camera.
One component of the front case should now be separate from the camera.
Remove the three (3.5 mm) screws from the bottom of the camera with the Phillips screwdriver.
Open the HDMI port, and remove the the two (3.5 mm) Phillips screws exposed on that side.
Remove the two 4mm screws from the interior of the battery pack, and one 3.5mm screw from beside it.
We already removed the screw next to battery lock. The one close to blue plastic lock.
How to repair this part of the interior pack if my blue thing is broken
Looking at the bottom of the camera, use the spudger to lift the rear case away from the camera body.
Using the spudger again, carefully pry from the top of the camera to remove the back frame.
The back frame is fragile, so use the spudger gently.
Pull the back pannel up starting at the bottom of the frame. There is a little hinge at inside the frame the top that will move up and make it much easier to remove the back panel (almost without effort)
The most difficult part of this disassembly is this plastic part. Very thin, flimsy and tend to easily break. Pay extra attention when prying this frame, especially the top part, between the screen hinges.
Update to my previous comment:
Remove the top case part where the shutter button, play button etc so that flimsy plastic frame can come out easily.
The back case should now be removed and look like this.
Does this part contain battery stopper?
I guess not. battery stopper is on the body.
Remove the two copper 2.25mm phillips head screws from the bottom of the camera.
Those are not actual copper by the way. I am using a magnet plate and they stick to it as they are steel. So most probably copper colored or plated steel screws.
Remove the copper 2.25mm phillips head screw from the side of the camera.
Use the spudger tool to unhook the neck strap anchor from the side of the camera with the navigation buttons.
Remove the six copper 2.25mm phillips head screws from the top of the motherboard assembly on the camera
On which step we removed the tripod mount screw?
skipped the step where they removed top with the shutter
Flip the main navigation button up behind the camera to further expose the frame
Lift the LCD screen straight up and off of the camera. The motherboard frame is attached and the assembly will easily separate from the camera.
The metal shield part, how did you lifted up? Did you remove the sticker?
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Remove the lead connecting the LCD screen and frame assembly to the motherboard. Using tweezers, pull straight out from the lead to disconnect
The LCD screen and frame should now be separate from the main camera and appear as shown in the image
Remove the small wire lead from the motherboard using the tweezers. Firmly grasp the lead wire near the connection and pull up from the motherboard at an angle. The lead will snap off of the mount.
On the top left corner of the motherboard, unhook the black grommet from the housing by pinching the small tab with the tweezers and lifting up.
On the top left side of the motherboard, remove the first lead from housing using the tweezers. Firmly grasp the lead with tweezers and pull straight out from the housing.
Next, remove the first lead on the right side of the motherboard. Using tweezers, tightly grasp the lead and pull straight out from the housing.
Remove the next lead on the side of the motherboard. For this lead, you may have to grasp it on either side with the tweezers as shown due to the lack of room beneath the lead. When securely grasped, pull straight out of the housing to remove the lead.
Remove the final lead on the opposite side of the motherboard with tweezers. Tightly hold and the lead on either side and pull straight out of the housing to disconnect.
On the lower side of the motherboard, you must remove the small metal frame that covers the socket-lead. Pinch the frame on each side with the tweezers and lift up to easily remove it.
Pinch the cylindrical socket lead on each side with tweezers and lift out from its housing to remove the socket-lead.
With all secondary leads removed, lift the motherboard away from the camera to expose the primary lead underneath. While holding the motherboard lightly in one hand, tightly pinch the primary lead near the housing with the tweezers. Pull the lead straight out from the housing to completely separate the motherboard from the camera.
The removed motherboard and camera body should now appear as shown.
How to replace sensor and shutter?
It you are replacing motherboard, it is best to leave the two remaining ribbons underneath attached to camera body. Instead remove ribbons from motherboard since it will be discarded. Also, you will need to solder leads for cylindrical socket and shutter button onto new motherboard.
I have a Sony NEX-6 mirrorless...Is the process essentially the same?
My sony nex c have a problem every time i ‘m opened it with a message of “camera error”. May i know what is the major problem of this?
One of the common failing part of this model
is the memory card board which is quite difficult to replace. This model requires a guide for that.
