crwdns2959928:0crwdne2959928:0 ↓Replacing the lens mount requires removing any lens that is already attached then simply removing the casing of the lens mount.
Hold lens and camera securely with two hands.
With the hand holding the camera, push down on the lens button. Twist the lens counterclockwise and pull out to release lens.
Using your screwdriver, remove the four (3.5 mm) Phillips screws on the front face of the lens mount.
Remove the silver plate by gently pinching with your fingers.
Now the black plate should be exposed. You can remove this again by gently pinching with your fingers and lifting up.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Using the tweezers, grab the thin silver ring and lift up.
The camera mount should now be barren and look like this.
