This Guide will show you how to replace your battery in your Headphones
Remove the earcups by carefully peeling them away
Remove the 4 screws on the inside by using a 00 head (Note: you should use an extremly thin screwdriver, one with changeable bits like the ifixit one is too big)
Remove the driver by pulling it out
Be careful to not demage the cable
Disconnect the battery connector and pull the battery out. There is light adhesive holding it in
pictures please
Battery is in the RIGHT Ear Cup.
