This guide will provide instruction for replacing the swivel plastic cover on the Sony Extra Bass headphones. This piece encases the swivel piece and can get damaged through wear and tear.
            Begin by laying the headphones down flat with the speakers facing up.
            Next, take out the screws that hold the front plate, using a J00 screwdriver.
            Repeat for both the left and right screws.
            Now that the screws have been removed, pull away the plastic casing that covers the swivel piece (directly above the speaker).
            Now that the swivel piece is exposed, use a J00 screwdriver to unscrew the center screw.
            Repeat this process on both sides if necessary.
            With the swivel screw removed, remove the plastic casing.
            Using a little amount of force, slide the plastic cover off of the headband.
            Pull the plastic until the cover is fully removed.
Necesito la pieza, dónde la compro?
