Sony Linkbuds (WF-L900) Battery Replacement
    • Try to ensure all batteries are drained to below 15%. This reduces the risk of nasty surprises if the batteries are damaged during removal.
  1. Sony Linkbuds (WF-L900) Battery Replacement, Open Earbud: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently press a razor blade into the seam around the bulb on the ear bud.
    • Take care to follow the seam because the razor can easily go off track and cut a little slice of plastic from around the seam.
    • Allow the razor to cut no more than 1mm into the seam around the whole bulb.
    • If necessary, run the razor a little deeper around the whole seam until the cap can be pulled off.
  2. Sony Linkbuds (WF-L900) Battery Replacement, Remove Old Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The battery cell inside is held in with red glue.
    • A little heat helps soften the glue. Use a heat gun or hair dryer.
    • The glue can be gouged out with a screwdriver until the battery can be convinced to pull out.
    • Take care not to short-circuit the battery.
  3. Sony Linkbuds (WF-L900) Battery Replacement, Install New Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The new battery can simply be pushed into position.
    • Use B7000 or any similar rubbery glue that has a needle applicator - apply around the seam and close the earbud.
    • Wrap a rubber band around the bud until the glue has fully cured.
    • Repeat for the second earbud.
Paul Dann
crwdns2935283:010/30/24crwdne2935283:0
295 crwdns2915208:0crwdne2915208:0
my one started distorting lhs. I had to open it to fix the membrane in place. Not quite the same as this tutorial but it helped me to find how to open it.
Hermes Almeida - crwdns2934203:0crwdne2934203:0
Can you please share how did you fix the distortion?
Pavlo Tkachenko -
crwdns2936753:07crwdne2936753:0 70
crwdns2936753:030crwdne2936753:0 418
crwdns2942667:0crwdne2942667:0 3,443
