In this guide, you will go through the process of removing the camera's LCD screen. Please note that this involves thorough disassembly of nearly the entire camera, and should only be done if you absolutely need direct access to the screen.
            Locate the slider labeled "BATT" and pull it back from the battery with your thumb.
            At this point, you should be able to remove the battery by simply lifting it from the camera.
            Use the Phillips #00 head to remove the following 5.5mm screws on the left-hand side.
            Use the Phillips #00 head to remove the following 5.5mm screws on the empty battery socket.
            Use the Phillips #00 head to remove the following 5.5mm screws on the bottom.
            Fold back the hinging panel on the top of the camera located near the lens.
            Use the Phillips #00 head to remove the following 5.5mm screws on the top under the hinging panel.
            Slide back the cover for the DC and A/V ports on the right-hand side.
            Use the Phillips #00 head to remove the following 5.5mm screws underneath the cover and on the right-hand side.
            Use the plastic opener tool to loosen the casing on the bottom and the right-hand side.
            Carefully remove the bottom casing with your fingers.
            Look at the right side of the camera (the side with the recording button) while holding back the detached casing.
            Use the Phillips #00 head to remove the following 5.5mm screws near the recording button.
   crwdns2935267:0crwdne2935267:0Tweezers$4.99-
            Use the curved tweezers to carefully detach the blue ribbon cable connector from the body of the camera.
            Pull off the top casing by lightly grabbing either side and pulling towards the back of the camera.
            Use the Phillips #00 head to remove the following 5.5mm screws on the inside of the top casing.
            Carefully remove the metal frame from the top casing.
            You are now free to remove the recording button, as well as its connection strip.
            Use the Phillips #00 head to remove the following 5.5mm screws on the right-hand side near the lens.
            Use the Phillips #00 head to remove the following 5.5mm screws on the top near the lens.
            Carefully pop off the casing strip on the camera's left-hand side near the lens.
            Use the Phillips #00 head to remove the following 5.5mm screws underneath the casing strip.
            Carefully pull the lens cover and shutter assembly off of the front of the camera.
            Use the Phillips #00 head to remove the following 5.5mm screws on the lens shell.
            Carefully remove the lens from the body of the camera.
            To begin removing the metal casing, use the Phillips #00 head to remove the following 5.5mm screws.
            Hold the camera so you can see the motherboard on its bottom.
            With a pair of straight tweezers, carefully remove the hanging panel by the following bundled cable connectors and ribbon cable connector attached to the motherboard.
            The camcorder's chip and part of the motherboard should naturally fall off at this point and should carefully be removed and placed to the side.
            Use the Phillips #00 head to remove the following 5.5mm screws from the side of the motherboard.
            Use the Phillips #00 head to remove the following 5.5mm screws and remove the lens compartment by carefully pulling it out of the metal casing.
            Use the Phillips #00 head to remove the 5.5mm screw inside the metal casing.
            Using a pair of tweezers, remove the ribbon cable connector attached to the metal casing and the motherboard.
            Using a pair of tweezers, remove the following ribbon cable connectors to remove the motherboard from the camcorder.
            Carefully remove the motherboard by hand.
            Rotate the display screen to access one of the two 5.5mm screws on the surface nearest to the camera body.
            Use the Phillips #00 head to remove the screw, then rotate the screen in the opposite direction to access and remove the other identical screw.
            Use the plastic opener tool to loosen the casing between the screen's front and back.
            Use the Phillips #00 head to remove the following 5.5mm screws underneath the back casing of the screen.
            Carefully use the tweezers to detach the following ribbon cable connectors.
            Use the tweezers to peel back the black tape covering the last ribbon.
            Carefully detach the ribbon cable connector attaching the screen from its back.
            The screen should now be free from the remaining camera body.
