This procedure only requires 2 tools and the most difficult part will be pulling the case off with your hands without breaking it.
Push in the battery indicator.
Use the Phillips #0 screwdriver to remove the two 5mm screws.
Use the Phillips #0 screwdriver to remove the three 5mm screws.
Use the plastic opening tool to loosen the plastic case of the camcorder.
Use your hands to remove the plastic case.
