Sony Handycam DCR-SR42 Hard Drive Replacement
  1. Sony Handycam DCR-SR42 Hard Drive Replacement, Hard Drive: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Handycam DCR-SR42 Hard Drive Replacement, Hard Drive: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the battery, and use the Phillips #00 precision screwdriver to then remove the three 3mm Phillips #00 screws under the battery.
    • Wait 1 hour after removing the battery before continuing to disassemble the camera.
  2. Sony Handycam DCR-SR42 Hard Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 3mm #00 Phillips screws on the bottom of the camera.
  3. Sony Handycam DCR-SR42 Hard Drive Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 3mm Phillips #00 screws on the side of the camera.
    • Remove the 4mm Phillips #00 screw under the AV port cover.
  4. Sony Handycam DCR-SR42 Hard Drive Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Handycam DCR-SR42 Hard Drive Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pull the black plastic hard drive cover away from the body of the camera. This will expose the hard drive.
    • Even with all the screws removed, this part will require some force to remove.
  5. Sony Handycam DCR-SR42 Hard Drive Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Handycam DCR-SR42 Hard Drive Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the hard drive out of the camera by grasping the grey rubber mounting brackets and pulling them upwards.
    • The hard drive is attached to the flex cable. Remove the hard drive slowly to prevent the flex cable from being damaged.
  6. Sony Handycam DCR-SR42 Hard Drive Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the rubber mounting brackets by pulling them off the hard drive.
  7. Sony Handycam DCR-SR42 Hard Drive Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully unplug the flex cable from the hard drive.
    Do not just pull out the cable, make sure you unlock the connector first. There is a full width black lever which you can lift with your fingernails.
    Peter van Nes - crwdns2934203:0crwdne2934203:0
Dan Muller
crwdns2935283:003/23/15crwdne2935283:0
1.128 crwdns2915208:0crwdne2915208:0
Baylor, Team 7-13, Williams Spring 2015 crwdns2935289:0Baylor, Team 7-13, Williams Spring 2015crwdne2935289:0
BU-WILLIAMS-S15S7G13
Gracias por el post. Muy buenas las explicaciones.
Una consulta.
Tengo filmadora SONY DRC-SR21 cuyo disco original es Toshiba MKL8034GAL.
Puedo usar un disco de 30GB para reemplazarlo ?
Intenté hacerlo pero al encender la filmadora, vuelve a apagarse.
El disco original es de 500mA y el de 30GB es de 400mA.
Gracias por la ayuda
JORGE - crwdns2934203:0crwdne2934203:0
Hi, that’s a very comprehensive tutorial, well done!
I’m trying to find out if I can access video footage recorded onto a sony handycam ( DCR-SR75) The LCD screen stopped working and I can’t seem to operate the memory. I would appreciate any advise or suggestions as how to sort this problem thanks, Ger
Ger O'Neill - crwdns2934203:0crwdne2934203:0
Any recommendations on bigger drives to replace it with? SSD?
Dave Thomas - crwdns2934203:0crwdne2934203:0
Where can I buy a replacement hdd to do this repair with?
Mark Lawrence - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 95
crwdns2942667:0crwdne2942667:0 7,010
