Sony Handycam DCR-SR 47 Speaker Replacement
  1. Sony Handycam DCR-SR 47 Speaker Replacement, Hard Drive: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery.
    • Use a Philips #000 screwdriver to remove the 3mm screw under the battery.
    • It is recommended that you wait one hour after removing the battery before disassembling the rest of the camera.
  2. Sony Handycam DCR-SR 47 Speaker Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the Phillips #000 screwdriver, remove all six of the 3mm screws located on the side of the camera.
    • This step seems unnecessary to initially find the hard drive, but will allow access to the attached flex cable.
  3. Sony Handycam DCR-SR 47 Speaker Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the Phillips #000 screwdriver remove the three 3mm screws from under the LCD screen.
  4. Sony Handycam DCR-SR 47 Speaker Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Handycam DCR-SR 47 Speaker Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #000 screwdriver remove the single 3mm screw on the back of the camera.
    • Pull away the back shell of the camera to expose the hard drive.
  5. Sony Handycam DCR-SR 47 Speaker Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Handycam DCR-SR 47 Speaker Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Handycam DCR-SR 47 Speaker Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently pull the flex cable away from the hard drive. It should pop off with minimal effort.
    • The black guard is removed in the first picture. While the guard is not necessary to access the hard drive and cable, removing it can be helpful to show the cable's path.
    • After removing the flex cable take off the plastic guard from the side of the hard drive.
  6. Sony Handycam DCR-SR 47 Speaker Replacement, Speaker: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Handycam DCR-SR 47 Speaker Replacement, Speaker: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the Phillips #000 screwdriver, remove the four screws from the housing under the hard drive.
    • Remove the top plastic housing of the camera. All screws attaching the housing have previously been removed.
  7. Sony Handycam DCR-SR 47 Speaker Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Handycam DCR-SR 47 Speaker Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Handycam DCR-SR 47 Speaker Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the Phillips #000 screwdriver, remove the two 3mm screws from the LCD Screen connector and the two 3mm screws on the front plate of the camera
    • Remove the two 3mm screws that were exposed through the previous image
    • Carefully detach the LCD Screen from the rest of the camera.
  8. Sony Handycam DCR-SR 47 Speaker Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove the lens covering from the camera in order to access the internal components
  9. Sony Handycam DCR-SR 47 Speaker Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Handycam DCR-SR 47 Speaker Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the spudger, remove the top housing where the hard drive was located.
  10. Sony Handycam DCR-SR 47 Speaker Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Handycam DCR-SR 47 Speaker Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the #000 Phillips Screwdriver, remove the one 3mm screw holding the speaker housing
    • Once the screw is removed, the speaker can be separated from the camcorder
  11. Sony Handycam DCR-SR 47 Speaker Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The speaker is now removed, and the speaker port is open. Replace the new speaker with the damaged one, and replace the one 3mm screw
Ragan Whitlock
crwdns2935283:008/26/15crwdne2935283:0
556 crwdns2915208:0crwdne2915208:0
Western Carolina University, Team 1-2, Virtue Fall 2015 crwdns2935289:0Western Carolina University, Team 1-2, Virtue Fall 2015crwdne2935289:0
WCU-VIRTUE-F15S1G2
crwdns2942667:0crwdne2942667:0 383
