Sony Handycam DCR-SR 47 LCD Screen Replacement
  1. Sony Handycam DCR-SR 47 LCD Screen Replacement, Hard Drive: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery.
    • Use a Philips #000 screwdriver to remove the 3mm screw under the battery.
    • It is recommended that you wait one hour after removing the battery before disassembling the rest of the camera.
  2. Sony Handycam DCR-SR 47 LCD Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the Phillips #000 screwdriver, remove all six of the 3mm screws located on the side of the camera.
    • This step seems unnecessary to initially find the hard drive, but will allow access to the attached flex cable.
  3. Sony Handycam DCR-SR 47 LCD Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the Phillips #000 screwdriver remove the three 3mm screws from under the LCD screen.
  4. Sony Handycam DCR-SR 47 LCD Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Handycam DCR-SR 47 LCD Screen Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #000 screwdriver remove the single 3mm screw on the back of the camera.
    • Pull away the back shell of the camera to expose the hard drive.
  5. Sony Handycam DCR-SR 47 LCD Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Handycam DCR-SR 47 LCD Screen Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Handycam DCR-SR 47 LCD Screen Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently pull the flex cable away from the hard drive. It should pop off with minimal effort.
    • The black guard is removed in the first picture. While the guard is not necessary to access the hard drive and cable, removing it can be helpful to show the cable's path.
    • After removing the flex cable take off the plastic guard from the side of the hard drive.
  6. Sony Handycam DCR-SR 47 LCD Screen Replacement, LCD Screen: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Handycam DCR-SR 47 LCD Screen Replacement, LCD Screen: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Philips #000 screwdriver to remove the two 3mm screws on the hinge securing the screen to the body of the camera.
  7. Sony Handycam DCR-SR 47 LCD Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Handycam DCR-SR 47 LCD Screen Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Philips #000 screwdriver to remove the two 3mm screws on the opposite side of the hinge.
    • The screen is now no longer attached to the body of the camera through screws.
  8. Sony Handycam DCR-SR 47 LCD Screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Handycam DCR-SR 47 LCD Screen Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the plastic opening tool, gently separate the LCD screen from its plastic housing.
  9. Sony Handycam DCR-SR 47 LCD Screen Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the spudger or your fingers, gently remove the smaller end of the flex cable from the LCD Screen.
  10. Sony Handycam DCR-SR 47 LCD Screen Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Handycam DCR-SR 47 LCD Screen Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the Phillips #000 screwdriver, remove the 3mm screw from the LCD screen.
    • The LCD screen may now be removed from the camera completely.
  11. Sony Handycam DCR-SR 47 LCD Screen Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Handycam DCR-SR 47 LCD Screen Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the old LCD screen and replace it with the new screen.
Ragan Whitlock
crwdns2935283:008/26/15crwdne2935283:0
556 crwdns2915208:0crwdne2915208:0
Western Carolina University, Team 1-2, Virtue Fall 2015 crwdns2935289:0Western Carolina University, Team 1-2, Virtue Fall 2015crwdne2935289:0
WCU-VIRTUE-F15S1G2
where can i buy a screen for this camera?
Triforce Studios - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 1,641
