The flex cable can control every electronic feature of the camera, from the LCD screen to the picture settings. Replacing the flex cable can completely fix a camera that shows poor resolution or is not responding to LCD screen commands.
Remove the battery.
Use a Philips #000 screwdriver to remove the 3mm screw under the battery.
Using the Phillips #000 screwdriver, remove all six of the 3mm screws located on the side of the camera.
Using the Phillips #000 screwdriver remove the three 3mm screws from under the LCD screen.
Using a Phillips #000 screwdriver remove the single 3mm screw on the back of the camera.
Pull away the back shell of the camera to expose the hard drive.
Gently pull the flex cable away from the hard drive. It should pop off with minimal effort.
After removing the flex cable take off the plastic guard from the side of the hard drive.
Using the Phillips #000 screwdriver remove the four screws from the housing under the hard drive.
Remove the top plastic housing of the camera. All screws attaching the housing have previously been removed.
Using the Phillips #000 screwdriver, remove the two 3mm screws from the LCD Screen connector.
Remove the two 3mm screws that were exposed through the previous image
Carefully detach the LCD Screen from the rest of the camera.
Carefully remove the lens covering from the camera in order to access the internal components
Using the plastic opening tool, carefully separate the LCD Screen from the back covering
Using the Philips #000 screwdriver remove the single 3mm screw from the top of the camera. This removal will allow the microphone port covering to be removed.
Using the Phillips #000 screwdriver remove the single 2mm screw from under the microphone port covering
Using the spudger, gently remove the smaller flex cable connector from the LCD screen.
*You may also gently tug the flex cable using fingers if no opening tool is available*
Using the Phillips #000 screwdriver, remove the one 3mm screw connecting the LCD screen from the housing.
Using the Phillips #000 screwdriver, remove the one 3mm screw from the speaker port
Detach the speaker and side of camera from the internal components
Gently pull the flex cable out of the connector piece.
How it should look after cable is out of the connector piece.
*a spudger may be used if necessary*
After removing the flex cable from the internal components, separate the LCD pivot arm housing from the flex cable using a spudger.
The old flex cable is now free and able to be switched with the new one.
Please where i can buy the flexible cables to Sony?
