Turn the camera so the back side, beneath the viewfinder, is facing you.
Locate the battery pack compartment.
Press the small release button near the battery compartment.
While pressing the button, slide the switch forward to unlock the battery.
Carefully pull the battery pack out of the compartment.
To reinsert, align the battery pack with the compartment.
Slide the battery back into the camera until it clicks securely into place..
Using a #00 Phillips screwdriver, remove the six 4.5 mm screws from the camera's bottom.
Remove the three 4.5 mm screws beneath the battery.
Remove the 2.9 mm screw from the right corner.
Remove the two 4.5 mm screws from the battery's right wall.
Remove the 4.5 mm screw under the output flap on the front of the camera below the lens.
Remove the two 4.5 mm screws at the top of the camera.
Remove the 4.5 mm screw from the disk side of the camera (next to the lens).
Extend the gray viewfinder, then gently remove the black plastic casing.
Remove the two 2.9 mm screws under the black plastic casing.
Gently pull apart the outer silver case and screen.
Remove the copper wire strip to detach the case from the camera.
