Sony H.ear On 2 Motherboard Replacement
  1. Sony H.ear On 2 Motherboard Replacement, Motherboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony H.ear On 2 Motherboard Replacement, Motherboard: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Start on the left side by using the plastic opening tool in the crease between the ear cup and plastic. Gently apply pressure until it separates.
    • Do not force any parts off as the plastic holders may snap off if too much pressure is applied.
  2. Sony H.ear On 2 Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony H.ear On 2 Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the JIS #00 Screwdriver to remove the 2 6.4mm screws holding in the motherboard.
  3. Sony H.ear On 2 Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony H.ear On 2 Motherboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony H.ear On 2 Motherboard Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • De-solder all 18 wire-connections on the motherboard.
    • Record wire positions on board for proper connections when re-soldering the replacement board.
    • Do not overheat joints while de-soldering to prevent board damage.
    • Please see How To Solder and Desolder Connections for help on soldering and desoldering connections.
  4. Sony H.ear On 2 Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony H.ear On 2 Motherboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the white ribbon cable by gently tugging on the white connector while holding the motherboard carefully in place.
  5. Sony H.ear On 2 Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently remove the old motherboard from the bracket assembly and replace and resolder motherboard.
Michael Long
crwdns2935283:004/15/19crwdne2935283:0
131 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S9-G11, Maness Spring 2019 crwdns2935289:0Cal Poly, Team S9-G11, Maness Spring 2019crwdne2935289:0
CPSU-MANESS-S19S9G11
where can i find a replacement motherboard for these headphones?
MTL - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 1,820
