Grip the lower portion of the back of the phone and slide downwards.
Lift battery at the rounded notch near the bottom of the phone.
Unscrew the four Torx screws from the backplate.
The backplate may begin to separate from the keypad face. Do not try to remove it yet.
The screws are T5 Torx screws, 5.6mm.
Using the Spudger, gently pry up the U-shaped grey cover below the keypad.
Remove the two Torx screws from below the cover.
These are T5 Torx screws, 8.6mm.
Gently work a spudger or a fingernail between the keypad face and the backplate.
Separate the keypad face from the backplate.
Holding the backplate away from the swivel, remove the 4 small Phillips screws and both stamped struts from the swivel assembly.
Note that only the bottom strut has a tab.
The screws are Phillips, 2.9mm
The back housing is now disassembled, and the swivel assembly is revealed.
Remove the four black Phillips screws holding the swivel assembly to the LCD section of the phone.
The screws are Phillips, 2.4mm
Gently remove the grey plastic cover at the top-rear of the LCD section with a spudger.
Remove the two Torx screws revealed under the grey cover.
The screws are Torx T5, 5.6mm
Gently pry off the front face, starting at the bottom slot.
Remove the Torx screws near the buttons.
Remove the black front plate.
Remove the button overlay, taking note of its position for reassembly. There are small grey nubs that correspond to holes in the overlay.
Gently release the small grey retaining clips around the outside of the display assembly.
Separate the display assembly from its backplate.
The LCD section is now disassembled.
The LCD display is connected to the device with a small flex cable. To release the cable, flip the small handle on the connector to an upright position.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Gently pull the flex cable downwards with a pair of tweezers.
Gently separate the side button component from the inner casing. It is attached with adhesive.
Gently pull the front button component away from the inner casing slightly. It does not need to be removed.
Remove the LCD screen by its white housing, pulling the flex cable through the slot from the other side of the casing.
The LCD has been removed! It can now be replaced with a functioning display.
