Sony Ericsson Xperia Play Battery Replacement
  1. Sony Ericsson Xperia Play Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the phone around so the screen is facing a flat surface.
  2. Sony Ericsson Xperia Play Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To remove the cover, use plastic removal tool on the seam of the case.
    • Once enough force is applied, you should hear a “click” sound which indicates that cover is loose.
  3. Sony Ericsson Xperia Play Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After the “click” noise, lift the cover with your finger.
    • Do not puncture the battery. This can result in a fire.
  4. Sony Ericsson Xperia Play Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Proceed with removing the battery by lifting the battery with a small plastic pry tool.
    • Use a plastic tool for safety. If a plastic tool is not available use your fingers.
  5. Sony Ericsson Xperia Play Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery from the device.
  6. Sony Ericsson Xperia Play Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the old battery id removed, slide the new battery, with the positive/negative indicator facing up, in so that the contacts of the battery make contact with the contacts of the phone.
  7. Sony Ericsson Xperia Play Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lightly press the battery into the phone so that it is secure.
  8. Sony Ericsson Xperia Play Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To put the cover back on, apply force until a "click" sound is heard.
Pieter Boersma
crwdns2935283:003/25/15crwdne2935283:0
371 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 7-3, Cichon Spring 2015 crwdns2935289:0UMass Dartmouth, Team 7-3, Cichon Spring 2015crwdne2935289:0
UMASSD-CICHON-S15S7G3
Has ifixit thought about trying to make a replacement battery that would work with this? It would be good to be able to get the battery from here as well, even if it is potentially a niche market for these old phones.
waytodawn0 - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 1,815
