Sony Ericsson QuickShare T630 Screen Replacement
crwdns2942287:0crwdne2942287:0Screens for cellular devices are prone to cracking or shattering. There are several prerequisite steps required to access and remove the screen in place in your device. This guide will show you how to access the screen in order to replace in.
Begin the disassembly by placing your Sony Ericsson QuickShare T630 on a flat surface.
Slide the protective panel on the backside of the phone downward and remove it entirely, revealing the battery underneath.
Remove the rubber plug located near the camera by gently prying upward with your fingers.
Gently lift the camera shield after removal of the rubber plug.
The T630 phone is really old and this plug may be hard to remove as it may be decomposed like black putty. It really doesn't need to be taken off, you can get the protector for the camera off without taking out the plug when the rubber is like this.
Pry the remaining panel to loosen its contact to the phone using a spudger.
Slide the panel upward to remove it completely.
Slide the aerial upward to remove it.
Remove the four screws located at each corner of the device.
Gently lift and remove the front panel of the phone after removing the screws.
Slowly lift the screen to reveal the green circuit ribbon connecting the screen to the phone.
Gently pull the ribbon from the circuit.
Remove the now disconnected screen.
there is a litttle lever on the connection on the circuit board that must be lifted up (a fingernail works fine) before pulling on the cable.
you can also remove the keyboard connection (orange ribbon cable) in the same manner as for the screen cable. You can also just lift out the circuit board if you want to change the entire outer case.
Remove the keyboard by slowly pulling it away from the circuit board.
To place a new screen, slide the green ribbon connector into the ribbon clamp that the defective screen was pulled from.
Worked well until the screen replacemet - ribbon cable would not go into clamp - phone plus new screen straight in the bin - a little gutted - but hey it was an old but loved phone.
