Sony Ericsson QuickShare T630 Screen Replacement
  1. Sony Ericsson QuickShare T630 Screen Replacement, Sony Ericsson QuickShare T630 Phone Enclosure: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Begin the disassembly by placing your Sony Ericsson QuickShare T630 on a flat surface.
  2. Sony Ericsson QuickShare T630 Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Ericsson QuickShare T630 Screen Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the protective panel on the backside of the phone downward and remove it entirely, revealing the battery underneath.
  3. Sony Ericsson QuickShare T630 Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the battery upward to remove.
  4. Sony Ericsson QuickShare T630 Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Ericsson QuickShare T630 Screen Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the rubber plug located near the camera by gently prying upward with your fingers.
    • Gently lift the camera shield after removal of the rubber plug.
    The T630 phone is really old and this plug may be hard to remove as it may be decomposed like black putty. It really doesn't need to be taken off, you can get the protector for the camera off without taking out the plug when the rubber is like this.
    Lami - crwdns2934203:0crwdne2934203:0
  5. Sony Ericsson QuickShare T630 Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Ericsson QuickShare T630 Screen Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry the remaining panel to loosen its contact to the phone using a spudger.
    • Slide the panel upward to remove it completely.
    • These steps will require a slight appliance of force.
  6. Sony Ericsson QuickShare T630 Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the aerial upward to remove it.
  7. Sony Ericsson QuickShare T630 Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Ericsson QuickShare T630 Screen Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four screws located at each corner of the device.
  8. Sony Ericsson QuickShare T630 Screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Sony Ericsson QuickShare T630 Screen Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently lift and remove the front panel of the phone after removing the screws.
  9. Sony Ericsson QuickShare T630 Screen Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Ericsson QuickShare T630 Screen Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Ericsson QuickShare T630 Screen Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • This step is NOT required for joystick maintenance or keypad maintenance and replacement! Continue on to step 10 if you are attempting to achieve either of these goals.
    • Slowly lift the screen to reveal the green circuit ribbon connecting the screen to the phone.
    • Gently pull the ribbon from the circuit.
    • Remove the now disconnected screen.
    there is a litttle lever on the connection on the circuit board that must be lifted up (a fingernail works fine) before pulling on the cable.
    you can also remove the keyboard connection (orange ribbon cable) in the same manner as for the screen cable. You can also just lift out the circuit board if you want to change the entire outer case.
  10. Sony Ericsson QuickShare T630 Screen Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Ericsson QuickShare T630 Screen Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Ericsson QuickShare T630 Screen Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the keyboard by slowly pulling it away from the circuit board.
    • There are no direct connections between the keyboard and phone.
    • These are all of the parts covered in this disassembly that make up the Sony Ericsson QuickShare T630.
  11. Sony Ericsson QuickShare T630 Screen Replacement, Sony Ericsson QuickShare T630 Screen: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Sony Ericsson QuickShare T630 Screen Replacement, Sony Ericsson QuickShare T630 Screen: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Sony Ericsson QuickShare T630 Screen Replacement, Sony Ericsson QuickShare T630 Screen: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To place a new screen, slide the green ribbon connector into the ribbon clamp that the defective screen was pulled from.
Jeremy
crwdns2935283:010/16/13crwdne2935283:0
181 crwdns2915208:0crwdne2915208:0
University of Maine, Team 1-1, Diaz Fall 2013 crwdns2935289:0University of Maine, Team 1-1, Diaz Fall 2013crwdne2935289:0
UMAINE-DIAZ-F13S1G1
Worked well until the screen replacemet - ribbon cable would not go into clamp - phone plus new screen straight in the bin - a little gutted - but hey it was an old but loved phone.
roger hiley - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 1,396
