Remove the battery cover.
Press down firmly with your thumb and slide the cover back.
Remove two Phillips #0 screws from the battery chamber.
Remove two Torx T6 screws from the battery chamber.
Remove the casing to expose the camera's components.
Gently pry open the front casing by working an opening tool along the entire seam.
Remove the front casing by gently lifting it from the phone.
Remove the screws holding the screen in place.
Gently lift the base of the keypad to remove it.
Gently pull up the green film, avoiding the joystick.
Works perfectly, thank you guys!
