Please note: you must remove the screws from the back casing before beginning this guide.
Remove two Phillips #0 screws from the battery chamber.
Remove two Torx T6 screws from the battery chamber.
Remove the casing to expose the camera's components.
Gently pry open the front casing by working an opening tool along the entire seam.
Remove the front casing by gently lifting it from the phone.
