In these instructions you will learn how to replace the joystick in a Sony Ericsson K750i
Remove the battery cover.
Press down firmly with your thumb and slide the cover back.
Remove two Phillips #0 screws from the battery chamber.
Remove two Torx T6 screws from the battery chamber.
Remove the casing to expose the camera's components.
Gently pry open the front casing by working an opening tool along the entire seam.
Remove the front casing by gently lifting it from the phone.
Remove the front cover and casing to expose the joystick.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use tweezers to get a grip on the joystick.
Once you have a firm grip, carefully remove the joystick.
Using tweezers, insert the new joystick in place of the previous joystick.
That is the joystick head and it can be removed without taking anything apart. The problem is in joystick underneath it, which is soldered and need to be replaced. I know this phone is 15 years old, I just found mine and it brought back some memories :)
