If you need to replace an old or damaged motherboard, access the motherboard with this guide. The motherboard is a vital piece for the Sony DVD player, It runs all systems making sure everything is running properly and smoothly.
Use a Phillips screwdriver to unscrew the five screws.
Use the Philips screwdriver to remove the screws located on the sides and the back.
Use a spudger to separate the case from the chassis.
Remove the case.
Remove all cables that are connected to the motherboard by pulling upwards from the motherboard.
Use a Phillips screwdriver to remove all screws located in the 4 corners of the motherboard.
Pull the motherboard up and out of the device.
